Hello. not finding my UMIK-1 mic under ASIO4ALL - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 22 Old 06-11-14, 09:17 PM Thread Starter
following these dirrections i can't seem to find my mic under step 5 and 6......
http://www.minidsp.com/applications/...dmi-on-windows
mic ordered from cross spectrom
thanks-
tommy281 is offline
post #2 of 22 Old 06-12-14, 05:51 AM
Re: Hello. not finding my UMIK-1 mic under ASIO4ALL
miniDSP-step5 wrote:
Audio devices don't always appear with obvious names, depending on the device and the version of Windows. In some cases, the UMIK-1 may appear just as "USB Audio Device." By hovering the mouse over the device you will get a popup window with more information that helps to identify the device. The UMIK-1, for example, will be an input device that runs at 48 kHz (only).
EarlK is offline
post #3 of 22 Old 06-12-14, 07:07 AM Thread Starter
Hello and thanks.
Yes. Did that and did not find the Mic or anything like 48 kHz.
tommy281 is offline
post #4 of 22 Old 06-12-14, 07:14 AM
Reboot the computer with the mic plugged into a different USB port .
EarlK is offline
post #5 of 22 Old 06-12-14, 08:24 AM Thread Starter
Thanks. Will give that a try later today n update this thread.
tommy281 is offline
post #6 of 22 Old 06-12-14, 05:14 PM Thread Starter
thanks. still nothing.
tommy281 is offline
post #7 of 22 Old 06-12-14, 05:33 PM
richard
I had to move my mic to a few different usb ports before it actually worked for me using my behringer. After a little messing around and restarting REW more than a couple times and setting it up in the playback control panel it finally worked. I also ran the windows speech recognition not sure If that helped or was needed but its how I did it.
Richard
socketman is offline
post #8 of 22 Old 06-12-14, 05:55 PM
tommy281 wrote: View Post
Too bad,
- if you have a USB extension cable plugged into the mic / get rid of it & reboot .
- if you have any other USB connected audio devices currently plugged into your computer, unplug them & reboot .
EarlK is offline
post #9 of 22 Old 06-12-14, 06:07 PM
Are you using REW V5.01 Beta 20?
jtalden is offline
post #10 of 22 Old 06-12-14, 06:31 PM
All these USB based mics ( Umm-6, UMIK-1, Icicle-XLR interface, etc. etc. ) need the USB Audio Codec ( driver ) to work.
- This generic driver is part of the operating system / though sometimes they get turned off ( or corrupted ) .
( Above ) is a connected audio device ( seen in, "Other devices" ) that can't find it's driver .
You might want to open up the Windows "Device Manager" & make sure the USB Audio Codec is installed ( & working properly ) .
EarlK is offline
asio4all , finding , mic , umik1
