Generating .frd and .zma files from REW that can be used by Passive Crossover Designer and WinPCD - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 3 Old 09-24-14, 05:10 PM Thread Starter
New Member
To use Passive Crossover Designer (or the Windows version, WinPCD) requires that you import the speaker frequency response as an .frd file or the impedance curve as a .zma file. The instructions for REW explain how to export your measurements as text files and state that the format is compatible with .frd and .zma files.
However I could not generate files from REW in a form that Passive Crossover Designer would recognise and I could not find an explanation how to do this on the web. After a bit of playing around I worked it out and I thought it might be useful for others if I posted how I did it.
Open the measurement you want to export from REW. Click the File Menu and then click Export and then ‘Measurement as text’. When you name the file you must add the file extension to the name. For example a woofer frequency file would be named woofer.frd
If you don’t do this the files generated by REW will by default have a .txt extension and Passive Crossover Designer or WinPCD will not recognise them.
I am running Windows 7 Home Premium edition and by default the file extensions are not shown in file names. I found it useful to change the computer settings so I could see the file types.
To do this, go to Start/ Control Panel/Folder Options and select View. Scroll through the advanced settings to ‘Hide extensions for known file types’ and unclick the box.
This will mean all your files will now show their type eg .doc .pdf .txt etc
I hope this information helps people with using these excellent programs.
Robert
robotc is offline
post #2 of 3 Old 09-24-14, 05:35 PM
Wayne Myers
Re: Generating .frd and .zma files from REW that can be used by Passive Crossover Designer and WinPCD
robotc:
Welcome to HTS, and thanks for sharing your discoveries.
AudiocRaver is offline
post #3 of 3 Old 09-24-14, 07:13 PM
HTS Senior Moderator
fusseli's Avatar
Cool, I didn't know PCD7 was ported to a windows app. I've done several designs using PCD7 and it's my go-to. It's what REW is to measurements and EQ to the speaker and crossover design world.
fusseli is offline
crossover , designer , files , frd , generating , passive , rew , winpcd , zma
