-   REW Forum (https://www.hometheatershack.com/forums/rew-forum/)
-   -   Mathaudio Room EQ (https://www.hometheatershack.com/forums/rew-forum/175466-mathaudio-room-eq.html)
snarf 07-29-19 01:12 PM
Mathaudio Room EQ
Does any one works with Mathaudio Room EQ or could make an comparison with other Roomcorrection software. Found it quite simpel to work with incomparison with REW The results are for me excelent. I work with Mathaudio in combination with Foobar2000 no cost involve.
carlthess40 07-30-19 07:57 AM
Re: Mathaudio Room EQ
Iím going to be downloading it this week
I see they have a lot of YouTube videos about the software ,unlike REW.
Sent from my iPhone using Tapatalk
frperdurabo 07-31-19 05:54 PM
I've been using it for several years, via the plug-in for Foobar2000. It works way better than not using any room correction, that's for sure. I get the best results using my home made dipoles (Eminence Alpha 15 + Fostex 103) probably because they're the best behaved in-room to start with.
snarf 07-31-19 10:00 PM
Same experience here the difference is hugh. If i go from bypas mode to room eq suddenly the band is playing like a band. For instance the abby road album from the beatles after 45 years i hear the bass of paul Mchartney much better the whole perfomance It sounds way more intimate.
frperdurabo 08-07-19 05:48 PM
snarf wrote: (Post 1614578)
Yeah, the weakest link in my system is the room. I've bought the Part Express USB measurement mic. My next upgrade, once I move to my new apartment, will be to use REQ with JRiversMediaCenter, which will allow for speaker correction, room correction, and time alignment.
perceval 08-28-19 05:59 PM
The MathAudio plugin is nice and easy.
Far more powerful is DRC room correction that not only corrects FR, but also phase, pre-ringing, etc...
There is a gui version of it, because it can be daunting at first with all the settings made through the config file.
Here:
http://www.alanjordan.org/DRCDesigne...ignerHelp.html
frperdurabo 09-04-19 05:57 PM
Thanks for the link. Just moved to my new place, am reading it now.
