-   REW Forum (https://www.hometheatershack.com/forums/rew-forum/)
-   -   Suggestions for external sound card for notebook (https://www.hometheatershack.com/forums/rew-forum/20110-suggestions-external-sound-card-notebook.html)
jbjb 07-21-09 10:04 PM
I downloaded REW, got the CM-140 SPL meter and cables, and was ready to run REW on my notebook when I spotted the note about NOT using the mic-in jack on a notebook.
How do I know if the jack on my notebook (a Dell Inspiron 6400) is mic-in or line-in? The description in the Vista Mixer says "Microphone / Line In". It uses the SigmaTel HD Audio Codec.
Assuming I need an external sound card to plug into my notebook. What's a recommended one?
tonyvdb 07-21-09 10:33 PM
Re: Suggestions for external sound card for notebook
jbjb wrote: (Post 178056)
Does it have a check box that alows you to select "line in"? if it does it may allow you to use it.
JC74 07-22-09 06:49 AM
1 Attachment(s)
Hi,
I have an XPS M1710 with the same card (running XP not Vista)
When you put a jack plug in the 'mic' socket you should get a pop-up asking if you want to use the mic or line-in :T
It works quite well but seems to roll a few dB off before 20Hz (see dashed line on attached)
The REW help file mentions a few makes/models of external card... I've just picked up a 'SB Live! 24bit' external sound card off ebay for a few pounds so I can see if its any better.
J
Anthony 07-22-09 07:23 AM
My old laptop had the Sigmatel drivers and it had a utility that let you select what each jack was (mid/line in), (line out, spdif, speaker), etc. I believe it was in the control panel or possibly it's own "Program Files" folder.
Good luck.
jbjb 07-23-09 01:38 AM
JC74 wrote: (Post 178102)
Anthony wrote: (Post 178107)
You're right guys.
When I plugged the jack into the input, this popped up:
http://www.hometheatershack.com/gallery/file.php?n=2823
So if I select "line in" I'm good to go for REW? What the difference between that and "microphone"?
Maksim Vus 07-23-09 04:15 AM
jbjb wrote: (Post 178265)
difference only in "Low" or "Hi" sensitivity (Hi - for microphone). But it just "program" parameter.
next step - check level in RAW. If you chose "Line" but level in RAW is too Low, then you can try "microphone". And vice versa.
Anthony 07-23-09 07:19 AM
Yeah, you are good to go there.
Line in and microphone have different sensitivities and I believe different input impedances. Bruce can talk better about that than I can. The line out from the SPL meter or mixing board are better matched with a Line In input on a sound card. The end result is you get more dynamic range measured and better signal to noise. All this ends up as a better measurement in REW.
Good luck.
