-   REW Forum (https://www.hometheatershack.com/forums/rew-forum/)
-   -   SPL meter no (https://www.hometheatershack.com/forums/rew-forum/54914-spl-meter-no.html)
a9155040 02-11-12 08:43 PM
SPL meter no
Hello
Recently, I buy behringer xenyx802+ECM8000 to play REW.
I have calibrate soundcard and check sound level.
Mic calibrate : I use ECM8000 calibrate file (download from website)
But, SPL value do not vary.
So what can I do ?
NegativeEntropy 02-11-12 10:47 PM
Re: SPL meter no
I'm not certain I understand your exact problem, but you need to calibrate the SPL level before the SPL readings will be meaningful (and I think it's supposed to throw a warning if you have not done this, the warning states that the SPL levels generated will be arbitrary if you do not calibrate first).
SPL calibration is done via the calibrate button on the SPL meter function within REW. See the help file for more detailed instructions.
