-   REW Forum (https://www.hometheatershack.com/forums/rew-forum/)
-   -   2 Sub measurements ,...then 3rd , straight line?? (https://www.hometheatershack.com/forums/rew-forum/73213-2-sub-measurements-then-3rd-straight-line.html)
randyc1 02-16-14 12:56 PM
I'm having problems with my REW Sub measurements, im able to take 2 correct measurements then the third is a straight line , it's driving me crazy ?
Have'nt used Rew in a little while, but i used to work fine ??
Using a EMC 8000 mic with ART usb dual pre.
randyc1 02-17-14 09:40 AM
Re: 2 Sub measurements ,...then 3rd , straight line??
Anyone have any ideas why ??
EarlK 02-17-14 11:41 AM
No idea why , but ;
In cases like this ( inexplicable REW behavior ), JohnM has recommended clearing REW's stored preferences & then re-opening the program ( usually with good results ).
:sn:
randyc1 02-17-14 08:12 PM
Do u mean like cal file , clear it and reload it ??
EarlK 02-18-14 06:50 AM
randyc1 wrote: (Post 681568)
No, I mean;
Choose " Delete Preferences & Shutdown " from the "Preferences" menu .
:sn:
randyc1 02-18-14 03:28 PM
EarlK wrote: (Post 681659)
No, I mean;
:sn:
??? I do not see that option anywhere in "Preferences" menu ????
EarlK 02-18-14 03:41 PM
1 Attachment(s)
:sn:
randyc1 02-18-14 06:27 PM
EarlK wrote: (Post 681810)
:sn:
Wow ok your right ,... i was going to the Preferences on the right first ??
Ok i will try and get back thanks !!
randyc1 02-19-14 07:29 AM
Well it did'nt work , after 2-3 measurements ,i'll take another and get a flat line. ??
Thanks anyways for trying to help !!
EarlK 02-19-14 08:01 AM
randyc1 wrote: (Post 681976)
That's too bad .
Have you made any changes to your measurement system ( such as a new OS being installed ? / a new computer maybe ? )
:sn:
