Dual box sealed 18" Mal X build begins. - Page 6 - Home Theater Forum and Systems - HomeTheaterShack.com
post #51 of 99 Old 06-23-10, 01:49 PM Thread Starter
claus_dk
Re: Dual box sealed 18" Mal X build begins.
B's Mach wrote: View Post
Nice craftsmanship! I'm going to steal that design for the bracing if you don't mind, LOL! Cut plans? Also, are the tops slightly curved, or an optical illusion from the camera?
They are infact slightly curved at the top.
Go ahead and use the bracing! I am myself curious if it will at all effect the sound compared to my old cabinet which had very little bracing.
clausdk is offline
post #52 of 99 Old 06-23-10, 01:52 PM Thread Starter
claus_dk
Drizt wrote: View Post
The bracing on those is AWESOME
Can't wait til you finish them and take some measurements in room Thats a lot of driver in a small box.
Yes, im very curious about that too!
I've modelled in unibox, and using heavy fill it models nicely even in this config. However it will demand more power.
Goal with these 2 subs is mainly quality rather than quantity in regards to nulls and peaks and one of my greater concerns is the EQ'ing of 2 subs!
Very torn about getting:
1) new reciever with multi eq xt - could serve multiple purposes i guess.
2) SVS AS EQ1
3) Use my BFD
4) antimode
Perhaps some of you have some insights into this dilemma?
clausdk is offline
post #53 of 99 Old 06-23-10, 10:20 PM
ben
do you have cut plans perchance....? the WAF factor on these is very good!
bensl is offline
post #54 of 99 Old 06-26-10, 12:38 PM
looks very nice. I learned in my car audio days that bracing can make a world of difference. Do a knock test and I bet it will sound solid, no clunky resonance.
Bracing and deadening makes a difference. Panel vibrations are energy that the drivers should be puting towards making sound.
If you really want to deaden the enclosure and set this build over the top have the inside of the enclosure sprayed with line-X.
BrianAbington is offline
post #55 of 99 Old 07-04-10, 03:42 AM
ben
any updates? im interested in your thoughts on how the smaller boxes perform compared to the others.
bensl is offline
post #56 of 99 Old 07-04-10, 03:55 AM Thread Starter
claus_dk
Sorry no real updates at this point.
Regarding cut plans - dont have any on them, but in reality just a square box with cut off corners and a curved top that is placed on the square box.
I bought 15 pillows though! which are intended as fill.
My painter "connection" is currently on holiday so I think we're into august before I get them returned from him.
Whats this line x spray btw?
clausdk is offline
post #57 of 99 Old 07-04-10, 04:34 AM
ben
yeah i was just being lazy asking for cut plans was really looking for a comparison in performance between the 2 boxes.
line x spray is spray on bedliner for trucks i think.
http://www.line-x.com/
bensl is offline
post #58 of 99 Old 07-04-10, 06:30 AM Thread Starter
claus_dk
bensl wrote: View Post
Ah, havent really considered lining the inside with anything other than the polyfill.
Yea, I'm very curious as to how the new subs will perform.
As I will end up with 2 subs I'm sure that it will be alot more output, but ill be sure to make some measurements up close to see the response of the sub un EQ'd.
I'm losing a little output down low with the smaller box but 2 subs will hopefully more than make up for that!
However, it will be a few months i think before its all up and running
clausdk is offline
post #59 of 99 Old 07-05-10, 02:06 PM
Nice build. The bracing looks like the Tony Gee Serious Sub.
Looking forward to seeing it completed.
clausdk wrote: View Post
Ah, havent really considered lining the inside with anything other than the polyfill.I'm very dubious that truck bed liner added to the inside of a sub, especially one already very well braced will make any difference at all.
Lucky7! is offline
post #60 of 99 Old 10-08-10, 01:38 PM Thread Starter
claus_dk
Small update.
Almost finished veenering one of the subs. First time I've done this! It's Ivory veener.
Getting the veener to stick on the curved top was challenging with the equipment I have.
A little bit sanding to go, then I'm trying to decide which coating to put on, how shiny etc....? any tips? high gloss is pretty unforgiving :P
Ups trying to glue on a little "mistake".
clausdk is offline
18" , begins. , build , dual , sealed
