Dual box sealed 18" Mal X build begins. - Page 7 - Home Theater Forum and Systems - HomeTheaterShack.com
post #61 of 99 Old 10-11-10, 03:45 AM Thread Starter
claus_dk
Re: Dual box sealed 18" Mal X build begins.
Here's some pics that belong in the first post. The imageupload I used back then was cancelled, so using picassa now.
#4
ADMIN: Images copied to first post.
There is no image for #4: http://lh3.ggpht.com/_lQIUSgiULvs/TD...02%20front.jpg
clausdk is offline
post #62 of 99 Old 10-11-10, 08:06 AM
I have updated that first post for you, but image #4 is not showing up.
Sonnie is offline
post #63 of 99 Old 10-11-10, 08:07 AM Thread Starter
claus_dk
I'm having some problems getting it linked, not sure why. Lets just leave it out then no worries.
clausdk is offline
post #64 of 99 Old 10-13-10, 08:07 PM
evilskillit's Avatar
Matt
If you need help linking images in Picasa let me know and I'll try to give you hand. I've been using Picasa for a while now and am somewhat handy with it.
evilskillit is offline
post #65 of 99 Old 10-15-10, 03:30 PM
Owen Bartley's Avatar
OJ
I really like these enclosures, very nice work, Claus. Did I miss the details about your curved top on the new cabs? I'd love to know how you did it. Did you use multiple layers of thinner material and bend them?
- OJ -
Owen Bartley is offline
post #66 of 99 Old 10-15-10, 04:15 PM Thread Starter
claus_dk
evilskillit wrote: View Post
Thanks.
I was able to link all the other pictures in the album, but for some reason that particular one kept making an error msg once linked into this board. I used the exact same procedure to link that one as the others.
clausdk is offline
post #67 of 99 Old 10-15-10, 04:21 PM Thread Starter
claus_dk
Owen Bartley wrote: View Post
Thanks alot.
The box is actually just square. The curve on the top is then shaped via hidden ribs. Like an airplace wing, then covered with a thin MDF sheet at the top. To make it rigid it's filled with foam!
Sides are cut in 45 degree angle.
All of this ensure no visible joints.
I experimented with laquer and it seemed that a 50% gloss was easy to work with and give it a prof look without being too much and also not revealing too many small errors in the veneer.
clausdk is offline
post #68 of 99 Old 10-18-10, 10:33 AM
OJ
Thanks, I figured it was something like that. Any pics of the interior? I'm trying to figure out the easiest/best way to do that type of curved top, while maintaining nice tight corners and seamless joints on the outside for finishing. I'm not quite sure how to make the 2 parts connect, unless you just slap it on and maybe flush router it after?
- OJ -
post #69 of 99 Old 10-18-10, 10:41 AM Thread Starter
claus_dk
This time around I had the cabinets delivered as they were build so cheap for me I couldnt match that price almost myself.
I'll ask him though how exactly he does it.
clausdk is offline
post #70 of 99 Old 11-01-10, 02:45 PM Thread Starter
claus_dk
Small update.
Almost done with one of the new 2 boxes. Just one more sanding then the final coat.
I'm REALLY considering the LMS ultra for these 2 new boxes instead of the Maelstrom. Thoughts? on paper they will perform almost the same but the LMS will have a lower system Qtc.
Don't mind the mess in the background, only place I can laquer and make a mess without getting into trouble
Here's the result so far.
clausdk is offline
18" , begins. , build , dual , sealed
