Peerless Push/Pull Sub Build - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 15 Old 12-21-09, 03:40 AM Thread Starter
Greg
Re: Peerless Push/Pull Sub Build
I really like the sound quality of the sub. As I said, it sounds great with music and it has enough output for movies in my small bedroom at home. The only thing I have considered changing is the possibility of adding some polyfill to the inside of the enclosure and see if there is any difference in sound. However there is a problem with this as the bottom of my enclosure has the cone of a driver in it.
I saw your build with the AV15-X drivers, nice work. I'm considering doing something similar in the future, possibly dual opposed AV15-X's, kind of like Mark Seaton's Submersive. That's a more expensive project though. Currently I'm working on a ported Tempest-X2 build in 7ft^3.
Dark Regent is offline
post #12 of 15 Old 12-21-09, 12:36 PM
Moonfly's Avatar
The 15's do sound really good. Just be prepared for the jump up in size
Moonfly is offline
post #13 of 15 Old 10-03-12, 03:17 AM
New Member
It looks really nice, I hope it sounds at least as good as it looks like Congrats!
legomedu07 is offline
post #14 of 15 Old 10-03-12, 06:09 AM
robbo266317's Avatar
bigbadbill
You have done a nice job on the cabinet. If it sounds as good as it looks it will be great.
Silence is golden but duct tape is silver.
DIY completed:
robbo266317 is offline
post #15 of 15 Old 09-07-17, 07:26 AM
Pending
Just stumbling on this post in 2017, it's like traveling through time. I just thought I'd offer an option for finishing MDF. I went to school for Industrial Design, and we had to make several scale models and MDF is often a material of choice. What we do to allow us to finish such a material with something like spray paint (MDF readily soaks up moisture through an unprepared surface) is you actually apply a few coats of Polyurethane to seal it, sanding in between. This also circumvents the need to add wood filler, as the poly will fill in the imperfections and sanding will smooth it all out. For any large issues, you can use Bondo between primer coats like you would with a car.
Fletch is offline
build , peerless , push or pull
