90 litre single 15" driver project. - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 48 Old 03-23-10, 09:57 AM
Ricci's Avatar
Josh
Re: 90 litre single 15" driver project.
The terraform XL is a variation on a 6th order design. One of the ports is replaced with PR's, useful when you can't get the port area you need.
Ricci is offline
post #12 of 48 Old 03-23-10, 10:04 AM Thread Starter
Moonfly's Avatar
It looks though as if the pr's fire into the internals of the port. Maybe not and I need to look closer, but either way its a beast.
Moonfly is offline
post #13 of 48 Old 03-23-10, 10:40 AM
gperkins
Dan,
The PR's are on the outside and the drivers are firing directly behind them so all you see on the outside is the PR's. Very unusual.
Its certainly a beast.
cheers
Graham
gperkins_1973 is offline
post #14 of 48 Old 03-23-10, 12:25 PM Thread Starter
Moonfly's Avatar
That actually makes more sense, and had I paid attention to what Ricci has said about it being a variation on a 6th order Bandpass design the penny would have dropped. Its a design Bose use a lot with small 6" drivers (I think they claim to have invented it) and for what they are the results are decent.
I can only expect doing it on this scale would be nothing short of spectacular. If I'm not mistaken Bose also follow this design on a larger scale, and they seem to impress people. I would expect Mark Seaton to offer much better VFM and results.
Moonfly is offline
post #15 of 48 Old 03-23-10, 01:29 PM
gperkins
Dan I was wondering how easy that would be to diy but with my two FIs and two 18" PRs and a slot port tuned very low. I wouldnt even know where to start with regards to modelling it. Im very curious. That sub is $3500 to buy.
graham
Posted via Mobile Device
post #16 of 48 Old 03-23-10, 08:29 PM
Lookin very professional Dan, did u do the spraying urself?
Mika75 is offline
post #17 of 48 Old 03-24-10, 05:51 AM Thread Starter
Moonfly's Avatar
gperkins_1973 wrote: View Post
graham
Just model a 6th order design in WinISD to get an idea of how it works. The hard bit would be swapping your ports for pr's, which you would almost certainly need to do. If you could do it with just ports you'll make the project cheaper, but I'm not entirely sure why you would want to do this.
I get the feeling part of the reason Bose use this design is to employ a low pass filter into the design of the sub itself and allow the sub to integrate with their sats better. The Bose design philosophy is one on its own. I'm not sure why Mark has chosen that design, although Bose reckon any distortion from the drivers is all caught inside the chambers inside the cabinet leading to a cleaner sound. I can only assume that is the part Mark is interested in. He's obviously chasing max spl, max depth and max clean signal.
Moonfly is offline
post #18 of 48 Old 03-24-10, 05:53 AM Thread Starter
Moonfly's Avatar
graham
Mika75 wrote: View Post
Ive done everything barring the final spray. The spraying bit takes all of a couple minutes, the prep work takes several hours. The place its done is at a garage that a friend owns, and he does the final spray coating in his spray booth.
Moonfly is offline
post #19 of 48 Old 03-26-10, 01:25 PM
Ricci's Avatar
Josh
Dan,
Bose uses an 8th order BP. That's their patented acoustimass dealio. Basically take the 6th order BP and where you have the 2 ports or PR's, one from each chamber, instead of hitting the outside world they vent into a 3rd chamber, which is itself tuned with PR's or ports. There are 2 freeware programs that I know of that will model these (8th order). They are very tricky though. WinISD can do 6th order.
Ricci is offline
post #20 of 48 Old 03-26-10, 03:48 PM Thread Starter
Moonfly's Avatar
Ah, interesting. Ive not looked into the Bose design closely enough I guess. I wander how that design would work if applied to a sub with proper drivers and amplification.
Moonfly is offline
15" , driver , litre , project. , single
