IXL 18.2.2 in sealed boxes - 1 driver or two? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 19 Old 06-13-10, 10:18 PM
lsiberian's Avatar
lsiberian
Re: IXL 18.2.2 in sealed boxes - 1 driver or two?
2 drivers are better than 1, but if the choice is between 1 driver in 4 boxes vs 2 drivers in 2 boxes. The 4 boxes will give you the best placement possible. Though only if your room allows.
lsiberian is offline
post #12 of 19 Old 06-15-10, 12:28 AM Thread Starter
Mat
Boxes are nearly finished, up to the point of designing grilles. I don't have the drivers yet (haven't made the circle cuts) and I can't find a dimension anywhere for how far the driver protrudes from the face it is mounted on; i.e. how much clearance the grille cloth needs from the mounting face.
Does anyone have an IXL 18.2.2 and can tell me how much clearance to allow from the face to the max driver extension? From the diagram on the Mach5 website I estimate it to be about 40mm (just over 1.5"). Is this right?
Thanks to anyone that can help.
mrel is offline
post #13 of 19 Old 06-15-10, 01:03 PM
Mike P.'s Avatar
Mike
Mine are surface mounted with 1.5" thick grills, no problems.
We're all in this together!
Mike P. is offline
post #14 of 19 Old 06-18-10, 04:08 AM Thread Starter
Mat
Thanks Mike, 1.5" it is.
Finished building the first box. I have a tendency to over-engineer things.... the box is 60kg without the driver. Oops!
Got no idea how I'm going to move these things when they have the 15kg drivers in them too. Sheesh!
mrel is offline
post #15 of 19 Old 06-18-10, 04:45 AM
Mike P.'s Avatar
Mike
Got any pics?
Mike P. is offline
post #16 of 19 Old 06-18-10, 11:51 AM
Moonfly's Avatar
Mike P. wrote: View Post
Got any pics?
I second that request
Moonfly is offline
post #17 of 19 Old 06-18-10, 07:57 PM Thread Starter
Mat
Ha!...and fair enough too, thanks to you guys for your help.
The first box is done and sealed - without the driver cutout (have to wait 4-6 weeks for stock to arrive ) there's not much to see - roughly a 24" cube with 1.5" walls...
As I make the second one I'll take some pics etc. It's a bit embarrassing after seeing your last build, though Dan. My excuse is these are temporary boxes (12 months max) so the bracing etc isn't very elegant.
But man is it heavy.
mrel is offline
post #18 of 19 Old 06-19-10, 05:51 AM
Moonfly's Avatar
I wouldnt worry about how it looks all that much, as long as its solid it will do its job. Routing the bracing like I have is pretty much pointless, but its easy to do so I do just because I like it. If your boxes are temporary then not finishing them makes sense too.
In the end we are all just enthusiasts, and we cant resist a look at a build
Moonfly is offline
post #19 of 19 Old 06-22-10, 07:14 AM
Depending on the amount of volume the driver requires, I'd say more drivers, more boxes
NoSnipeLimit is offline
18.2.2 , boxes , driver , sealed , two?
