Sealed TC Sounds LMS Ultra 5400 18" NOOB STYLE!! - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
 2Likes
post #21 of 446 Old 05-05-12, 08:01 AM Thread Starter
Re: Sealed TC Sounds LMS Ultra 5400 18" NOOB STYLE!!
Only thing i forgot to mention yesterday, is that my crown ce4000 came in. kinda bugs me that the fan is a little loud. was expecting something whisper quiet. Its not overly annoying loud when its idling. but.... going to have to brainstorm on this way to try and find a way to deaden the noise
brandon123 is offline
post #22 of 446 Old 05-05-12, 11:08 AM Thread Starter
Here are a couple pics of the Amp and Sub. Also went to a couple garage sales this morning and the guy had 4 clamps for sale. got all 4 of them for 15 bucks. a lucky find
post #23 of 446 Old 05-05-12, 04:57 PM
Mike
Wow, I was away from the comp for a couple of days and you sure did put in some work in that time
sub_crazy is offline
post #24 of 446 Old 05-05-12, 05:04 PM
Mike
I was just thinking
You mentioned you are a steel worker, do you also work with aluminum? You could always make an enclosure out of metal. I know one of the most expensive subs in the world, the Krell, is made out of aluminum.
post #25 of 446 Old 05-05-12, 05:24 PM Thread Starter
sub_crazy wrote: View Post
Well, i'm trying. So far its going good. I screwed up one of my corners. It fell and knocked a chip out of it. I have no idea how i'm going to fix it. I am going to post a picture. do you think wood filler could fix that?
post #26 of 446 Old 05-05-12, 05:29 PM
Mike
There is a wood epoxy that I have used a couple of times that works great. I just went to the garage and it's called Quickwood
I picked up mine at the Home Depot and it really works good and dries fast.
post #27 of 446 Old 05-05-12, 05:37 PM Thread Starter
Went this morning and got a new piece of wood and recut the front panel because the first one was to big. This time i made sure it was right on the dot. Worked out great. I posted a picture (one with router bit) of the one i cut yesterday on top of the one i cut today, so you can see the gap difference i was talking about. So now as you can see, all of my pieces are cut and ready to try my hand at glueing
post #28 of 446 Old 05-05-12, 05:42 PM Thread Starter
Figured i would start out with the front panels. Wasn't to sure how much glue, so i put alot on....Yep, it made a mess. Glad i had all of the extra clamps. Seemed so easy to align the boards with no glue, then with the glue on the thing was like a slip and slide. wasn't able to get it perfect, but its pretty close
post #29 of 446 Old 05-05-12, 05:44 PM Thread Starter
Now onto the assemble of the box!!!!!! I originally wasn't going to use screws but figured what the . What can i use that will sand my box down and not screw up the MDF board???
post #30 of 446 Old 05-05-12, 05:46 PM Thread Starter
Now i got to put my terminal in the back of the box. Add bracing, think i'm going to silicone the inside. And i got to figure out what i'm going to do for feet
240 volt , birch , crown ce 4000 , diy , lms-5400 ultra , mdf , sealed
