Single SI HT 18 build - Page 5 - Home Theater Forum and Systems - HomeTheaterShack.com
post #41 of 73 Old 01-18-13, 08:46 PM Thread Starter
Re: Single SI HT 18 build
Sanding day.
Time to roundover the side edges. I started with a 3/4" bit then moved on to the 1" bit. It went surprising smoothly.
Thats it for today, if I get a chance tomorrow I'll get some primer on.
Code Red is offline
post #42 of 73 Old 01-18-13, 09:07 PM
would look really cool if you painted the mdf and stained the plywood with a glass top. looks really good
txredxj is offline
post #43 of 73 Old 01-18-13, 09:17 PM Thread Starter
Thats an interesting idea, too bad I used cheap home depot plywood, the stuff is really junk. Next time I'll source out some good stuff and pay the extra money.
Code Red is offline
post #44 of 73 Old 01-18-13, 09:37 PM
Harold
Send a message via AIM to Harold Dale Send a message via MSN to Harold Dale Send a message via Yahoo to Harold Dale
Yea home depot has terrible "cabinet" grade ply. I don't know any respectful cabinet maker that would use that .
Harold Dale is offline
post #45 of 73 Old 01-18-13, 10:14 PM
Wayne Myers
Wow, really really nice work! Attention to detail! Reminds me of a cabinet I built decades ago for guitar speaker, only yours looks GOOD! (Mine did NOT.)
AudiocRaver is offline
post #46 of 73 Old 01-19-13, 11:51 PM Thread Starter
Thanks audiocraver I appreciate that. As I start the finish, as it were, I realize that there have been some lapses in the attention to detail though. I knew that having the plywood showing with butt joints instead of designing with rabbet joints and having only mdf on the outside was going to create finish problems. Mdf and plywood just sand at different rates even using a hard sanding block. That and all of the screw holes. I knew this going in and opted for strength over a perfect finish beings that the sub will be behind the mains stuck in a relatively dark corner. The finish doesnt have to be perfect. Ill leave that for when I build some new mains and center.
Heres a shot of the back before I started with the primer.
After the first coat of primer.
I decided to use a good spackle to fill the smallest holes that the wood filler left.
This is a better shot of it.
After sanding and another coat of primer.
After 5 coats of primer.
Ill probably give it a few more coats because you can still see the color difference between the plywood and the mdf.
Code Red is offline
post #47 of 73 Old 01-20-13, 12:34 AM
Harold
Yea MDF can really suck up a lot of primer. Looking great though!
post #48 of 73 Old 01-20-13, 02:22 AM
HTS Senior Moderator
chrapladm's Avatar
Papi
Looks great. Primer is always key in all my finishes.
"Music is the space between the notes"
[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.
chrapladm is offline
post #49 of 73 Old 01-21-13, 12:37 AM
Nice job. What primer are you using? Is it sprayed?
Zestforlife is offline
post #50 of 73 Old 01-21-13, 01:14 AM Thread Starter
I used Kilz 2 latex. I just used a foam brush as I didnt want to go to the trouble of making a separate spray tent in my garage, or move it outside. I didnt have a problem with brush strokes that even a foam brush leaves as it will blend in with the paint method I plan on using, and as I said before, the sub will hide in the corner anyway. I put it on vertically in long even strokes from top to bottom except for the top, there I went from front to back.
I painted the back today just to see how it will look and I think it will turn out OK. I'll post pics when I get it further along.
Code Red is offline
18 , build , ht , si , single
