Jl audio 13W3V3-4 40 liter closed box: The best of one world - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 42 Old 04-05-13, 06:45 PM Thread Starter
morca's Avatar
morca
Re: Jl audio 13W3V3-4 40 liter closed box: The best of one world
JL drivers are just as good for HT use ,I got 2 closed in a 40 liter box each in the living.
And a bandpass whit a 40 liter closed box for HT use.
The driver are indeed a little more expensive,but the can handle a lot.
JL drivers are extremly good i think.
For a litle for what it really cost,s i build my own F113 or Gotham.
morca is offline
post #32 of 42 Old 04-11-13, 01:28 PM
I've changed my mind, I'm going to go with an acoustic elegance 12" single sub design.
replicant_impulse is offline
post #33 of 42 Old 04-12-13, 12:13 PM Thread Starter
morca's Avatar
morca
Looks good to,spec,s are ok,what are you paying for a unit.
Wich 12 inch do you mean ?
morca is offline
post #34 of 42 Old 04-16-13, 03:37 AM
AE TD12X for $285. Sure its $85 more expensive but it has amazing performance and reliability behind it. The following design is what I want. Push Pull isobaric.
http://www.hometheatershack.com/foru...diy-sub-3.html
post #35 of 42 Old 04-16-13, 03:48 AM
I can't decide whether or not to build 2x of the subwoofers you built with the driver you used or go with 2 separate JL Audio 13W6V2D4 subwoofer enclosures, a single isobaric with the JL Audio 13W6V2D4, 2 drivers(to save space), or 2x Acoustic Elegance td12x isobaric from the link I listed above.
I decided to go with Class A/B amps rather than the Class D. So I've been looking at a Samson SX-1200 as the amp to use for this build then running a Mini DSP. I was thinking of modifying the amps with some higher grade Nichicon KG capacitors. I read in another forum that the stock capacitors are low quality so I should upgrade them.
I saw a guy on audiogon selling 2x Elemental Designs A5s-325 which has the 13" driver from them. I really wanted these subs but I'm concerned if the woofer goes bad I'm kind of screwed. I don't think the JL Audio's 13" would match up if I tried to swap those in.
post #36 of 42 Old 04-16-13, 03:55 AM
HTS Senior Moderator
chrapladm's Avatar
Papi
If your in the USA there are better options than to use an expensive AE driver for a true HT sub. If you are using this in a music sub then they are great.
"Music is the space between the notes"
[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.
chrapladm is offline
post #37 of 42 Old 04-16-13, 03:57 AM
I want 60% music 40% movies.
post #38 of 42 Old 04-16-13, 04:38 AM
chrapladm's Avatar
Papi
Location?
That type of wants would be better for sealed or ported 22hz. But I dont want to derail this thread into anthers.
post #39 of 42 Old 04-16-13, 11:11 AM Thread Starter
morca's Avatar
morca
I would say,build a bandpass/vented and a closed system whit 2 unit,s from JL.
Playing misic only whit the closed,HT use whit the bandpass and the closed togheter,souns great.
You get the best of both world,s.
JL driver a expensive indeed,butt i think they are word any euro i payed.
morca is offline
post #40 of 42 Old 12-21-13, 06:04 PM
New Member
Hey all. My search for good quality subs in my country, as also the minidsp i buy (amasing little fellow) lead me here and read your posts regarding the JL subwoofers. So today i am a happy owner of my first 13W3V3-4 and after the new years eve i will make the box, sealed one. I wanted to make 2 sealed in the same time but the next will be on a later time.
I have a couple of questions morca. You have the inuke 3000dsp as also the hypex d4. Atm i will use the free channel on my rotel for the sub. For the future i am between ep2000, inuke3000 or a couple of hypex for the set up. You see differences from inuke to the hypex ones? Your responce will help me a lot
mariosbs is offline
40 , audio , box , closed , jl , liter , world
