Noobie questions... - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 04-11-13, 01:44 PM Thread Starter
Noobie questions...
I just finished building a DIY sub based on the Zaph Audio model. I must say I am impressed by the sub but it appears my room is too big for a 12" sub (18x25x10'). Another issue was the fact that the cherry veneer did not come out too good, it was blotchy which I don't understand (I used wood conditioner, my prior walnut veneered Polk came out fine).
I ordered a Dayton Audio RSS390HO-4 15" driver. I am planning to base the build on the "Drake" design except on a larger scale. I figured that an 18" cube with one inch sides will be about right (Later, I plan to buy another amp to rebuild the 12" sub to augment the 15" sub. I want to make both subs identical in size and looks, black gloss lacquer.).
I want to use the original 500-watt amp from the 12" Zaph build for the 15" sub. Is the amp strong enough for the 15" driver?
jon96789 is offline
post #2 of 11 Old 04-11-13, 07:06 PM
Personally i think the driver needs a bigger cab to get the best from it and i think the amp will be ok. But in that size box it may struggle.
scottthehat is offline
post #3 of 11 Old 04-11-13, 08:37 PM Thread Starter
Re: Noobie questions...
from the TS parameters, the 18" driver will have a Qtc of 0.635, so I think it is large enough. Right now, it's the output that I have questions on...
jon96789 is offline
post #4 of 11 Old 04-11-13, 10:20 PM
Mike P.'s Avatar
Mike
I can't find any model on the Zaph site that is a subwoofer.
http://www.zaphaudio.com/
What 12" driver is it, what is the net volume of the cabinet, and what 500 watt amp does it use?
As for the RSS390HO-4, a 18" cube built of one inch material will have a net volume of 2.1 cu.ft. Once I know what amp you have and the HPF it employs I can model it.
We're all in this together!
Mike P. is offline
post #5 of 11 Old 04-12-13, 11:53 AM Thread Starter
Go to the archive section... It is 1/4 down the list... I attached a PDF of the web page below...
I attached my Bass Box Pro build sheet for the Zaph Audio subwoofer. It uses the Dayton Audio RSS315HF-4 and the Dayton Audio 500-watt sub amplifier. The Qtc is 0.620
I also attached my build sheet for the 15" RSS390HO-4 "Drake" plan. In a 18" cube and the amp isolated in a subchamber, the end Qtc is 0.615.
Thanks in advance...
jon96789 is offline
post #6 of 11 Old 04-12-13, 12:19 PM
Mike P.'s Avatar
Mike
The net volume for the Zaph is 2.2 cu.ft. and the net volume for the 390HO is 2 cu.ft., correct?
Mike P. is offline
post #7 of 11 Old 04-12-13, 01:01 PM Thread Starter
The Zaph build is 2.0 cubic feet net... The 15" Drake is 1.3 cubic feet net. The details are in the PDF files.
jon96789 is offline
post #8 of 11 Old 04-12-13, 04:09 PM
Mike P.'s Avatar
Mike
My modeling shows the 390HO in 1.3 cu.ft. as a Q of .764, not .615.
Mike P. is offline
post #9 of 11 Old 04-12-13, 06:34 PM Thread Starter
hmmm.. Can you look at my build DA 15HO.PDF above and check the parameters? I reviewed it again and it all looks good to me at 0.615....
jon96789 is offline
post #10 of 11 Old 04-12-13, 07:24 PM
Mike P.'s Avatar
Mike
The parameters you have listed are correct, I checked mine as well. WinISD shows 1.68 cu.ft. for a Q of .7 and 2.66 cu.ft. for a Q of .615.
Mike P. is offline
noobie , questions
