Unknown sealed sub (dual 12") - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 06-10-13, 01:46 PM Thread Starter
BoomieMCT's Avatar
Boom
I've been using an OB dipole sub for a while to compliment my OB mains. Since EQ'ing my mains though, the sub gets outperformed by the mains and doesnt' have much to add. As such I've decided to repurpose the parts (two unknown paper subwoofers and a Dayton 240 watt plate amp) to make a single dual driver sealed sub that will fit in my corner and double as a stand for one of my girlfriend's statues.
Real quick, I'm thinking about 3 cubic feet with two of these drivers;
Power handling: 150 watts RMS/250 watts max
Le: 2.75 mH
Impedance: 8 ohms
Re: 6.9 ohms
Frequency range: 20-3,000 Hz
Fs: 20 Hz
SPL: 84 dB 1W/1m
Vas: 87.8 L
Qms: 4.42
Qes: .48
Qts: .43
Xmax: 8 mm
SD: 480 cm^2
Theoretical freespace F3 is 35Hz (see attached), which is fine for music. Build pics and tests to follow.
BoomieMCT is offline
post #2 of 11 Old 06-10-13, 01:49 PM Thread Starter
BoomieMCT's Avatar
Boom
Re: Unknown sealed sub (dual 12")
Incidentally, if anyone wants an open baffle sub enclosure for two 12" drivers, PM me.
post #3 of 11 Old 06-10-13, 01:56 PM
Mike P.'s Avatar
Mike
In your modeling, did you account for the amps hi-pass filter?
We're all in this together!
Mike P. is offline
post #4 of 11 Old 06-10-13, 01:58 PM Thread Starter
BoomieMCT's Avatar
Boom
Mike P. wrote: View Post
Nope. Nor did I account for the 35 Hz Bass boost (defeatable) or room gain. I figured once built I'd put it in the room I'd measure and tune. The mains go down to 45ish Hz so the HP filter will be set pretty low.
post #5 of 11 Old 06-10-13, 03:39 PM
Mike P.'s Avatar
Mike
You should add the 18 hz hi-pass as it will affect the low end.
Mike P. is offline
post #6 of 11 Old 06-10-13, 05:19 PM Thread Starter
BoomieMCT's Avatar
Boom
How does one do that?
post #7 of 11 Old 06-11-13, 06:01 PM Thread Starter
BoomieMCT's Avatar
Boom
Getting the enclosure glued up and the electronic gear.
post #8 of 11 Old 06-11-13, 08:32 PM
Mike P.'s Avatar
Mike
BoomieMCT wrote: View Post
I'm not sure how to do it in the program you're using, I use WinISD.
Your cabinet looks great.
Mike P. is offline
post #9 of 11 Old 06-12-13, 07:23 AM Thread Starter
BoomieMCT's Avatar
Boom
I supposed I could make or find a comparable .frd file for unibox, but it won't change much in the design. From the excursion graph you can see I already can't run this one hot if I want it to stay linear. OTOH, this is for music, not HT, so I'm not too worried about that.
post #10 of 11 Old 06-13-13, 10:04 PM Thread Starter
BoomieMCT's Avatar
Boom
Bracing done. Top is glued and drying (not shown). I probably won't be able to do more work until next week but next week I'll probably get a FR at least.
boomiemct , sealed , subwoofer
