Sub woofer behind screen - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 9 Old 06-16-13, 07:40 PM Thread Starter
I'm putting my speakers behind my screen and want to know if I can put my sub woofer behind it as well?
The screen is a mesh and looking forward to hiding all of the speakers.
Thanks for the help.
Read more: http://www.hometheatershack.com/foru...#ixzz2WQfyxqJf
melret is offline
post #2 of 9 Old 06-16-13, 07:57 PM
HTS Senior Moderator
chrapladm's Avatar
Papi
Re: Sub woofer behind screen
Yes you can place your sub behind the screen. Bass frequencies are much harder to "hide." So if your regular L/R and others can go back there then your sub will be no problem.
"Music is the space between the notes"
“[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.”
chrapladm is offline
post #3 of 9 Old 06-16-13, 08:23 PM Thread Starter
Thanks for the help, it will make a much cleaner job!!
melret is offline
post #4 of 9 Old 06-19-13, 01:08 PM
Owen Bartley's Avatar
OJ
melret, a few things to keep in mind if you are putting your sub behind your screen. You should still try to find the optimal location for it, if possible, rather than just plunking it down. If you have any flexibility in positioning (corner, mid-wall, etc.) it would probably pay off to test before designing. Also, if you're building ported, make sure the port isn't firing into the screen or you may get some movement. By the same logic, you wouldn't want the actual driver very close to the screen.
- OJ -
Owen Bartley is offline
post #5 of 9 Old 06-19-13, 05:13 PM Thread Starter
Thanks for the information. I have plenty of options. There is no limitations as to where it goes. When you say test it out, how do I do that? I can put it in front of the screen, I have lots of room but thought it would like better if it was behind like my speakers.
melret is offline
post #6 of 9 Old 06-20-13, 04:17 AM
hjones4841's Avatar
Silly Girl!
melret wrote: View Post
He probably means either listening to see which location is the best, or better yet, measure the sub's frequency response with a tool like REW, which is available here at HTS.
Many of our members do the "subwoofer crawl," which means putting the sub at the main listening position and then moving around the room until the sub sounds the best. Then put the sub there.
Measuring with software and a calibrated microphone is by far the best method, but finding the best location with the crawl will help a lot also.
Hug your pet today!
hjones4841 is offline
post #7 of 9 Old 06-21-13, 11:40 AM
OJ
^^ Yep, that's it! There are a bunch of things you can try, but the subwoofer crawl seems to be the easiest way to get a generally good result. You can experiment with the sub in different locations behind the screen too (L corner, 3/4 along wall, midpoint on wall, R corner, etc... I think there's a rule about not being equidistant between 2 walls, so 1/3 or 3/4 will probably give you better results).
- OJ -
post #8 of 9 Old 06-23-13, 09:34 PM Thread Starter
This is really cool all the help I'm getting to make this right...thanks.
melret is offline
post #9 of 9 Old 06-23-13, 09:38 PM
chrapladm's Avatar
Papi
Its why we are all here.
screen , woofer
