Help what to buy and how to connect REW - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 17 Old 11-21-14, 05:37 PM Thread Starter
niklasmagnus
Hi all,
looking for a budget REW setup. I already have a old SB X-fi 5.1 (SB1090) usb sound card at home. My plan is to buy the Dayton EMM-6 mic, but I'll need some kind of phantom power pre- mic amp.
Will I be able to use the X-fi and still get the timing reference loopback feature? If I want to measure the delay and phase and delay for multi subs and room phase. If it work, should the pre-mic amp be connected to the mic in or the line in on the X-Fi?
If the X-Fi will not work, may I use the Beringer UM2, it's a cheap usb sound card? If not, may you please help me pick another one from the site thomann .de/se/cat.ht ml?gf=usb_ljudinterface&oa=pra
I live in Sweden and this site offer many alternatives at good pricing.
BR Niklas
niklasmagnus is offline
post #2 of 17 Old 11-21-14, 05:49 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Help what to buy and how to connect REW
I doubt you can find a separate mic pre amp w/ phantom power that will be cheaper than the UM-2, so I’d go for that. From what I can see it looks like it should work. However, if you want to be absolutely safe you should get one of the sound cards recommended in our REW Sound Card Database.
post #3 of 17 Old 11-22-14, 04:26 PM Thread Starter
niklasmagnus
Thanks Wayne, will look in to that thread again.
I misunderstood the shipping cost from Parts-express to Sweden, It's $10 more than the actual mic. So I will probably not buy that one. A Behringer ECM8000 may be an better option, however, it is not calibrated.
post #4 of 17 Old 11-22-14, 04:38 PM
ellisr63's Avatar
Ron
Have you looked here for a mic?
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (5) JBL 8340As, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, Oppo UDP-203, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #5 of 17 Old 11-22-14, 05:17 PM Thread Starter
niklasmagnus
Yes, the total price including shipping will be same as the Dayton from Parts-express.
But thanks =)
post #6 of 17 Old 11-23-14, 02:36 AM
I just tried rew with a simple mic that was connected to the mic port of my laptop. It was not calibrated but for creating DRC curves calibration is not a MUST. Try it and you will see a major improvement in sound.
shkumar4963 is offline
post #7 of 17 Old 11-23-14, 06:43 AM Thread Starter
niklasmagnus
Sorry but DRC curves=?
post #8 of 17 Old 11-24-14, 02:12 AM
I mean the equalization filter that you can then use in Foobar2000 or miniDSP.
post #9 of 17 Old 11-24-14, 05:36 PM Thread Starter
niklasmagnus
shkumar4963 wrote: View Post
Okay, then I understand. Thanks.
Just ordered a Dayton EMM-6 from Amazon, still expensive shipment but a lot cheaper compared with Parts-Express.
Think I go with the Behringer UMC22 $87, but not sure yet.
post #10 of 17 Old 11-24-14, 06:46 PM
Check out Umik 1. I talked with the guy who developed REW he said this will work fine.
buy , connect , rew
