Best settings for sensitivity - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 4 Old 06-01-15, 04:17 PM Thread Starter
Hi folks.
I want to measure the spectrum analysis of the computer fan. For this job, i buyed umk-1. And i use rew.
I made this record the regular calibration file ( No sound in a room. Dead Silence)
http://i.imgur.com/BMz3pyt.jpg http://i.imgur.com/JPsHRAS.jpg http://i.imgur.com/nnhEYir.jpg
What settings do you recommend for a more accurate and more sensitive measurements.
There are examples of this address .
http://www.coolingtechnique.com/rece...owall=&start=6
http://www.coolingtechnique.com/img/...800-7-9-12.png
OneTreeHill is offline
post #2 of 4 Old 06-02-15, 06:41 AM
Lumen's Avatar
Lou
OneTreeHill wrote: View Post
Hi folks. I want to measure the spectrum analysis of the computer fan. For this job, i buyed umk-1. And i use rew. I made this record the regular calibration file ( No sound in a room. Dead Silence)....
Hello, OneTreeHill. First of all, let me see if I understand and you correctly. You used a recording of dead silence as the calibration file. Which calibration file do you mean? The mic or the sound card? If it's the mic, then you can get a generic calibration file from minDSP. You can get a more accurate calibration done by Cross Spectrum Labs.
Sent from my iPad using HTShack
I try to be as good as my dog thinks I am
Lumen is offline
post #3 of 4 Old 06-02-15, 07:52 AM Thread Starter
Re: Best settings for sensitivity
BlueRockinLou wrote: View Post
I used minidsp calibration file and i get this results. Is this normal? As I said, there was no sound in the room.
Thank you for reply.
post #4 of 4 Old 06-02-15, 11:28 AM
Lumen's Avatar
Lou
I don't see anything unusual. Your noise floor is around 40dB which is quite good for a residence. There appears to be a deep null at 15Hz and peaks at 50 & 100Hz. It's hard to tell from your graph (variable smoothing would help). No need to repeat it, because you'll perform a near field measurement on the fan. Room response won't come into play (except for the noise floor). Please post future graphs according to the guidelines explained here.
Lumen is offline
sensitivity , settings
