Experiment on Road Noise during Commute - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 12 Old 06-22-15, 04:18 PM
tonyvdb's Avatar
Tony
Re: Experiment on Road Noise during Commute
XEagleDriver wrote: View Post
QUESTION:
RESULTS: Average dB was 99, low value was 74, and high value was 107
Wow, your Camaro's interior is really noisy. I only get around 70-75db average in my van driving mostly freeway to and from work using audio tools on my iPhone And it never peaks over 80db.
Home theater:
Living room system:
tonyvdb is offline
post #12 of 12 Old 06-23-15, 06:53 AM Thread Starter
XEagleDriver's Avatar
XEagleDriver
tonyvdb wrote: View Post
Tony,
It turns out the van is probably not quieter than the Camaro, but rather the iPhone App is a better SPL tool than the Android app I used.
REPEAT WITH SPL METER: On today's commute, I drove the same route and used the same method as previously stated, except I used a Radio Shack SPL meter (picture below) set to A-Weighting and Slow response as Talley suggested and the SPL (dB) readings were as follows:
- On the Interstates at ~68 mph readings of 70+/-2 dB;
- On smooth 2-lane Hwys at ~60 mph readings of 68+/-2 dB;
- On rough 2-lane Hwys at ~66 mph readings of 72+/-2 dB.
This analog meter does not capture highest/lowest values or calculate the overall trip average like the cell phone, but from what I observed the lowest was 60dB when standing still and the highest was ~76 dB when travelling over bridge seams at speed.
These values tracked much closer to what I was hearing, basically a quiet cab with audible pavement noise in relation to road quality.
I did toggle back and forth between A-Weight and C-Weight, as well as Slow and Fast response:
- C-Weight read a lot closer to the cell phone readings, but still reported ~10 dB less than the phone.
- Slow versus Fast did not appreciably change the peak readings, just the amount of needle movement.
CONCLUSIONS:
1) The phone app is C-Weighted and also inaccurate reading about +10 dB high (basically a toy).
2) The noise levels in the car most likely do not pose a significant risk, as they are well below the OSHA A-Weight standards Talley contributed.
Cheers,
XEagleDriver
Last edited by XEagleDriver; 06-23-15 at 06:56 AM. Reason: Can't typ[e worth . . .
XEagleDriver is offline
commute , experiment , noise , road
