UMIK-1 with long USB cable - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 15 Old 08-04-15, 12:08 PM Thread Starter
Pierre
Re: UMIK-1 with long USB cable
For now I am happy with my standard account ;-)
phabaudio is offline
post #12 of 15 Old 08-06-15, 09:33 AM Thread Starter
Pierre
I received the UMIK-1 today. The accompanying USB cable is 10 feet long !
I'll have a try adding a 10 feet long passive extension cable. If it does not work I'll order a 16 feet active extension.
post #13 of 15 Old 08-08-15, 11:50 AM Thread Starter
Pierre
The UMIK_1 connected with a 20 feet (6 m) USB cable works great ! No need for an active extension (I just added a passive 10 feet extension to the 10 feet cable provided with the mic).
post #14 of 15 Old 08-09-15, 09:41 AM
BoredSysAdmin's Avatar
Your milage with USB extension cables will vary significantly, depends on length and quality of cables to requirements. I believe these usb mics only use USB per much slower 1.1 spec, which means it's not as critical for example as 1080p webcam.
BoredSysAdmin is offline
post #15 of 15 Old 08-09-15, 10:00 AM Thread Starter
Pierre
The extension cable I am using is a low cost one from Amazon. But your are right, the bandwidth requirements for a microphone are not very high, much lower than for a cam.
cable , long , umik1 , usb
