sensitivity is 10mV/Pa microphone is this spl - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 4 Old 11-04-15, 01:34 PM Thread Starter
Hi if a mic has a sensitivity of 10mV/Pa can I use this for SPL on the top of the calibration file.
If not can I convert this for SPL?
Thanks in advance
Phillips is offline
post #2 of 4 Old 11-05-15, 02:16 PM
REW Author
JohnM's Avatar
John
Re: sensitivity is 10mV/Pa microphone is this spl
You could try this procedure.
JohnM is offline
post #3 of 4 Old 11-05-15, 03:08 PM Thread Starter
JohnM wrote: View Post
Thanks John so its not as easy as putting the sensitivity 10mV/Pa on top of the calibration file?
Is there another way I can use that info, it is a USB mic?
Is it accurate to put a another mic with calibrated SPL next to each other and adjust?
I want as close to accurate as possible.
Thanks again
Phillips is offline
post #4 of 4 Old 11-05-15, 03:47 PM
REW Author
JohnM's Avatar
John
If you have an SPL meter you could calibrate against that. If you don't, but you had a USB mic REW knows how to handle you could set up the known mic, load its cal file, play a pink PN signal, note the SPL reading, then connect your other mic, load its cal file (if it has one), position it exactly where the previous mic was, play the same pink PN signal at the same volume and in the SPL cal dialog enter the SPL reading you had from the first mic.
JohnM is offline
10mv or pa , microphone , sensitivity , spl
