SRM Turtle beach help! - Page 5 - Home Theater Forum and Systems - HomeTheaterShack.com
post #41 of 47 Old 12-17-08, 01:01 PM
Ricci's Avatar
Josh
Re: SRM Turtle beach help!
Hmm. It does look like a filter is on. I'm guessing that it is something in the SRM control panel settings. Not sure what as I don't have it to look at right now.
Ricci is offline
post #42 of 47 Old 12-19-08, 02:15 PM Thread Starter
Brit
Holy !! I think it worked, let me know if this is correct?
sendtobrit is offline
post #43 of 47 Old 12-19-08, 02:37 PM
REW Author
JohnM's Avatar
John
Looks good.
JohnM is online now
post #44 of 47 Old 12-19-08, 02:45 PM
Ricci's Avatar
Josh
It's still a little bit more rolled off on the low end than the usual, but much better. If you aren't concerned with measuring below 10-15hz anyway who cares.
What was the problem?
Ricci is offline
post #45 of 47 Old 12-19-08, 02:51 PM Thread Starter
Brit
BTW the SRM was on 5.1 instead of two speakers that is what did the trick!
post #46 of 47 Old 12-19-08, 02:52 PM Thread Starter
Brit
Is there anything you can think of that might help in that region (10-15hz)?
post #47 of 47 Old 12-19-08, 05:53 PM
It's fine.
To prove it's OK, simple connect a cable from the right channel line-out to line-in (just as you did to make the soundcard cal file), and take a Measure from 0-10000Hz. (be sure to run the Check Levels routine and Calibrate SPL first).
The resulting measurement should return a perfect straight line, if your cal file is correct.
brucek is offline
beach , help! , turtle
