how to read SPL level in my room? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 12 Old 05-16-16, 10:06 PM Thread Starter
Hi guys, noob here,
Probably asked a milllion times... I'm interested in getting the Dayton EMM-6 mic and downloading REW for setting up my 2 satellites and sub. I see how I can get all the eq response and comparison levels for the speakers with this mic and software, but how do I know the actual SPL in my studio?
You're supposed to set up the system at around 85 dB, right? Do I have to get an SPL meter as well? Can you just calibrate / test things at a comfortable listening level and not worry about the absolute level?
Thanks much,
Desaavik is offline
post #2 of 12 Old 05-17-16, 08:27 AM
tonyvdb's Avatar
Tony
Re: how to read SPL level in my room?
Yes, ideally getting a hand held SPL meter is the best option or in a pinch you can download an SPL app on your phone I use the AudioTools app on the iPhone and its quite accurate as Ive compared it to my handheld meter that I also own.
Home theater:
Living room system:
tonyvdb is offline
post #3 of 12 Old 05-17-16, 11:11 AM Thread Starter
OK, yeah thanks, I'm not actually trying to EQ up my room at the moment, just calibrate my 2.1 system... but thought that I could kill 2 birds with one stone if I got a decent reference mic.
Which SPL meter should I get ? The only one I can see that would be a reasonable accurate unit is the Galaxy CM140. But it's more than I want to spend at $129 street price. Anything else out there you'd recommend ? Needs to read down to 40hz or so.
Desaavik is offline
post #4 of 12 Old 05-17-16, 11:46 AM
tonyvdb's Avatar
Tony
I have the Galaxy CM140 and its a nice meter, radio shack meters will also suffice. Honestly if you have an iPhone the AudioTools app works well. (it may also be available for Android)
Home theater:
Living room system:
tonyvdb is offline
post #5 of 12 Old 05-17-16, 12:00 PM Thread Starter
tonyvdb wrote: View Post
thanks, but don't have a mobile phone....
Desaavik is offline
post #6 of 12 Old 05-17-16, 02:27 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Might try finding a used Galaxie meter on ebay. Oh yes, welcome to the Forum!
post #7 of 12 Old 05-17-16, 04:51 PM Thread Starter
10-4 and thanks for the welcome, Wayne
Desaavik is offline
post #8 of 12 Old 05-18-16, 09:02 AM
An option is the UMIK-1 or UMM-6 mic instead of the EMM-6. These 2 USB mics come with a cal file that includes the sensitivity factor. That means the mic can be used with the REW meter for sound level readings (just as the Galaxie SLM would provide) or for normal REW usage.
jtalden is online now
post #9 of 12 Old 05-18-16, 11:37 AM Thread Starter
jtalden wrote: View Post
Aaargh... timing is everything... thanks for the tip...
I just ordered a Nady DSM-1X... but now looking at the UMIK-1 specs, application notes, I don't see anything about that mic with REW being able to read just SPL, per se.
Desaavik is offline
post #10 of 12 Old 05-18-16, 02:56 PM
REW includes a very capable built-in SLM function. Check out the REW Help information on that function. It will do everything most common handheld SLM's will do, and more. The only proviso is that when using an XLR mic or line level mic the REW meter must first be calibrated for the attached mic sensitivity and the input gain. In the case of the UMIK-1 REW will pickup the sensitivity of the mic from the MiniDSP (or CSL) provided mic calibration file. It also detects the USB gain settings so no external meter is needed to calibrate the REW meter.
A separate SLM is very handy to own also, as it can be easily moved around as needed for various mobile uses. It just isn't necessary if using REW and the Umik-1 mic for the typical listening room setup.
level , read , room , spl
