Which mic setup is "best"? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 12-11-08, 07:58 PM Thread Starter
TJ
I spent some time searching (although maybe not very well) for what may be a good mic to use for REW. I've been using the software for some time very successfully with my old style Radio Shack meter. What I want is to start using REW for more than just my sub. I'd like to start using it to help treat my room and understand how the rest of my frequency response is doing. I'd like to see what changes I make look like compared to just what they sound like. So I'm looking for a good mic setup and I of course know about the ECM8000. Is this what I should get, or are there other alternatives that may be better? I'm not looking to spend a bunch of money, but if there is a good reason I should consider something else, please let me know.
Thank you.
TJHUB is offline
post #2 of 11 Old 12-11-08, 08:13 PM
tonyvdb's Avatar
Tony
Re: Which mic setup is "best"?
The ECM8000 is a very good choice but you will still require a mixer of some sort like this one as the ECM8000 has an XLR connector and you can not connect that directly to a PC.
Another less expensive option is to get a better SPL meter. The Galaxy CM140 can be found here and is much more accurate than the Radio shack meter. A calibration file is also available for it.
Home theater:
Living room system:
tonyvdb is offline
post #3 of 11 Old 12-11-08, 08:23 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
If money is tight (being close to Christmas and all), you can eBay the mixer and mic for 40-50% less than what they cost new. These items are typically used by recording hobbyists and are not abused, like more "serious" pro gear often is, so they're a pretty safe bet bought used.
post #4 of 11 Old 12-11-08, 08:39 PM
tonyvdb's Avatar
Tony
Surprisingly enough the price for the ECM8000 on ebay is more than what Musicians friend has them for.
And same goes for the ebay listings for the Mixer
Home theater:
Living room system:
tonyvdb is offline
post #5 of 11 Old 12-11-08, 08:59 PM
Yeah, I should have mentioned that there is no shortage of vendors selling new items. Look for individuals selling actual used items...
post #6 of 11 Old 12-11-08, 09:18 PM Thread Starter
TJ
Thank you gents! I appreciate the info very much.
Looks like I'll be ordering the ECM8000 and the mixer tomorrow. I'm looking forward to my new adventures with REW.
TJHUB is offline
post #7 of 11 Old 12-16-08, 10:46 AM
oddness
A good, cheap mic can be built using a Panasonic WM-61A electret mic capsule available from Digi-Key electronics for under $2. If you are using a Creative SB Live, Audigy, Audigy2, etc, you already have a mono mic input that provides 5volt dc power for the mic. The mic can be built into a stick type ball point pen housing (papermate,e.g.) See the attached diagram for wiring. You will need only a 2.2K ohm resistor and a 10uF capacitor. Which mic setup is "best"?-calibration-mic.jpg
oddness is offline
post #8 of 11 Old 12-16-08, 10:51 AM
tonyvdb's Avatar
Tony
That wont work with REW unless you have made a calibration file for it.
Home theater:
Living room system:
tonyvdb is offline
post #9 of 11 Old 12-16-08, 01:21 PM
Plain ole user
lcaillo's Avatar
Tech Guru
The best mic is the one that is calibrated or that is at least compared to a reference mic.
lcaillo is offline
post #10 of 11 Old 12-16-08, 01:32 PM
bjs
bjs
These capsules are extremely linear and hardly need a calibration file for HT use if mounted properly (I use a straw of exact diameter).
Having tested several mics, I'd take the capsules over commercial mics using someone elses calibration file. The only way to do better is to get an individually calibrated mic...needed for serious speaker design...but not so much for HT.
bjs is offline
"best"? , setup
