Galaxy CM-140 Calibration File Info Thread - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 45 Old 03-10-07, 05:41 PM Thread Starter
Re: Galaxy CM-140 Calibration File Info Thread
It is my honor to do so... I want nothing less than as good as I can provide for everyone...
Sonnie is offline
post #12 of 45 Old 03-13-07, 10:17 AM
Eric
Sonnie wrote: View Post
Secondly and most assuredly something that will excite several of you... my ECM8000 is going to be calibrated down to at least 5Hz. Once it is returned, I will hopefully be able to provide you with a calibration file to 5Hz or lower for the CM-140.
This is awesome Sonnie. Thanks much for doing this! Can't wait to get it and put it to use.
Eric
Eric_RP is offline
post #13 of 45 Old 03-15-07, 12:24 PM
Ivan
Thanks Sonnie !!
ifeliciano is offline
post #14 of 45 Old 03-16-07, 11:41 AM
jim
Are you having the high end done, and above 8khz? Now I think I should have bought a 140 instead of getting my RS charted...Jim
nerdful1 is offline
post #15 of 45 Old 03-16-07, 12:05 PM Thread Starter
The initial plans are to provide a calibration file for the bass region. I will provide some measurements full range, but I'm not sure anyone is going to be up to the task to complete a calibration file for it. It would be a fairly gruesome task IMO.
Sonnie is offline
post #16 of 45 Old 03-16-07, 12:27 PM
Vader's Avatar
Derek
Sonnie,
I have always read that the Rat Shack meter is 2 to 3 dB low when using the pink noise on DVE to calibrate (ie. when the meter reads 72 dB it is actually about 75 dB). Does the Galaxy meter need a similar correction factor?
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
- Not liable for injuries sustained while laughing.
Vader is offline
post #17 of 45 Old 03-16-07, 01:28 PM Thread Starter
I'm not sure how anyone could qualify that correction. Your response is not perfectly flat and the SPL meter is going to read the highest peak in your response when that pink noise is playing. If that peak is at 500Hz, then neither meter is really going to need any correction, yet if it were at 20Hz it would... but with pink noise how can you tell where the peak is unless you have an RTA. I think most of the time we see peaks down low in the 30Hz to 60Hz region. With the old RS meters it could mean anywhere from 2db - 7db of correction, with the newer RS meters it could mean from .5db - 2db and with the CM-140, it would not need any at all in that region. So ultimately, I would say you would not need to perform any corrections to the CM-140 for pink noise.
Sonnie is offline
post #18 of 45 Old 03-16-07, 02:40 PM
Vader's Avatar
Derek
Sonnie,
Ron had me use that correction when we were trouble-shooting my first cylinder last year. He had me run several tests using both my AVR test tones and DVE (which is 10dB hot on the sub test). When I reported the results of the sub tests, I thought they were all 2-3 dB low, but Ron said they were spot-on, because of this correction. Based on this, I calibrated the subs to "flat" with respect to the meter, so it would really be 2-3 dB hot (or so I understood).
Edit: My wife just called and said that my meter came today, so I guess I'm gonna be re-calibrating tonight. It will be interesting to see how far off my old Rat Shack meter really is (I bought it when I was in college - 1991 - and have never re-calibrated it...). Thanks so much, Sonnie!
Peace... Vader
Vader is offline
post #19 of 45 Old 03-16-07, 07:28 PM
Ilkka's Avatar
Ilkka
Vader wrote: View Post
Sonnie,
DVE's pink noise is not good for setting up the subwoofer level. It's too wide band to be accurate if your frequency response isn't close to dead flat. Especially any amount of "room curve" can cause one very interesting results. AVIA and pretty much all receivers have band limited pink noise for setting up the subwoofer and speaker levels. Usually the noise for subwoofer is limited in ~40-80 Hz range. Since normal C-weighting reads around 1-2 dB low in that range, the same amount of correction is needed for the CM-140 too. So adjust your subwoofer to output around 73-74 dB on the CM-140 when using your receiver as the source. With DVE it's much more difficult to define the correct compensation but around 2 dB is a good starting point. Your ears should always be the final judge, don't just blindly trust on the SPL meter. If the subwoofer sounds too loud, turn it down.
Ilkka is offline
post #20 of 45 Old 03-16-07, 08:14 PM
Vader's Avatar
Derek
Ilkka,
So you would recommend that I use the AVR's TT instead of DVE? I had always heard that DVE was the better way to go because it tests the entire signal path (from DVD player --> AVR to Speakers --> SPL meter). What you say makes perfect sense too. What about the other channels? Would it be better to simply calibrate all of them to keep consistancy, or use DVE for everything except the LFE channel? I know, I need to get AVIA.... just haven't gotten around to it yet.
Peace... Vader
Vader is offline
calibration , cm140 , file , galaxy , info , thread
