REW Sound Card Database - Page 10 - Home Theater Forum and Systems - HomeTheaterShack.com
post #91 of 118 Old 06-20-15, 01:22 PM
REW Author
JohnM's Avatar
John
Re: REW Sound Card Database
TomFord wrote: View Post
I downloaded the REW, but was confused on how any adjustments I made in it would translate into all (or at least components aside from laptop) of my system.
After seeing the gear some of you are using, does connecting it to a beringer like many of you have allow you to get the adjustments the software makes into your AVR, DVR, PS4, Oppo?
If you want to apply REW's EQ suggestions you will need an external equalizer of some sort Behringer or miniDSP for example), or EQ filters in your processor, or a software EQ such as EqualizerAPO if you are playing audio from your PC.
JohnM is offline
post #92 of 118 Old 08-02-15, 04:24 PM
Too bad this post didn't include frequency response graph for all these cards with some information. well here's M-audio Mobilepre test. -1 dB down at 20K
kc999 is offline
post #93 of 118 Old 08-02-15, 05:59 PM
And this is my ESI [email protected] which I've always used for measurements. don't get any flatter than this up to 24k. too bad they don't have this in USB.
kc999 is offline
post #94 of 118 Old 09-02-15, 01:12 PM
Barry
Need external soundcard advice!.
Looking at an ASUS Xonar U5 5.1 Channels 24-bit 192KHz soundcard. Works with WIN 7 on my laptop and I already have the Behringer ECM8000 mic and a Sound Devices MP-1 pre and phantom power supply. With ASIO drivers the latency is supposed to be 2ms and FQ of 48K.
My other option is a Creative Sound Blaster X-Fi Surround 5.1 Pro USB Audio System with SBX SB1095 24-bit 96KHz.
Any thoughts? Thanks for the advice!!!
Barry100 is offline
post #95 of 118 Old 09-02-15, 02:11 PM
I'm expecting a Behringer U-PHORIA UMC202HD 24-Bit/192 kHz USB Audio Interface this week will do some frequency plots on that.
kc999 is offline
post #96 of 118 Old 09-02-15, 08:33 PM
umc202hd very flat
kc999 is offline
post #97 of 118 Old 12-31-15, 11:46 AM
Ramon
Friends Forum:
I apologize because my English is very bad. I will appreciate information about external USB Targeta "Focusrite Scarlett Solo" and microphone Behringer ECM 8000, work well with REW V5.1; OS Windows 7 32-bits?
Grateful for your help, greets
Ramon
ramonnavarro is offline
post #98 of 118 Old 01-10-16, 07:12 AM
Mr^Mania
Its been awhile from my last posted... upgraded to REW 5.1 recently and below is my measurement tools :
Mic: Behringer ECM8000 (Calibrated by me via Tenma 72-8530 Sound Level Meter Calibrator)
Audio Interface: TASCAM US144mkII
OS: Windows 7 Pro 64-bit
Sound_Project is offline
post #99 of 118 Old 01-13-16, 06:39 AM
Marko
Are the Focusrite Clarett series soundcards compatible with REW?
I'm interested in the 4Pre model. It looks to have a Thunderbolt interface instead of the USB. Is that a problem? My laptop is Asus Zenbook UX31A and it runs on Win8.1. I have been using M-Audio Fast Track Pro with REW for years before, but now I would like to upgrade.
EDIT: I just found out that the Clarett series is currently not compatible with Win8.1, which is a bigger problem in my case. Still, I'm interested in the REW compatibility for the future plans.
Castore is offline
post #100 of 118 Old 01-13-16, 02:41 PM
REW Author
JohnM's Avatar
John
Thunderbolt cards are aimed at OS X, although it is possible to buy Thunderbolt interfaces for PCs. It would be much easier to go for a USB interface, but there's no need to change if you are only using the interface for acoustic measurement - making measurements places quite modest demands on the soundcard and just about anything can do a decent job, no need for a high end interface.
JohnM is offline
chain , rew , signal , survey
