New Dayton Audio UMM-6 USB mic - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 84 Old 11-24-12, 02:16 PM Thread Starter
Mike
I just got the new Parts Express 2013 catalog and they have a new measurement mic listed. It is not showing up on the website yet so it's not available to order but in the catalog it lists for $88.26. It looks like the Omnimic but it instead black.
I took a pic of the product page:
I am thinking this will work with REW?
sub_crazy is offline
post #2 of 84 Old 11-24-12, 06:01 PM
Wayne Myers
Re: New Dayton Audio UMM-6 USB mic
Looks like it could possibly be an excellent candidate for use with Room EQ Wizard. One important thing to find out: does each individual unit come with its own a factory-supplied calibration curve? Calibration microphones in this price range typically do not, so if this one does, that would be a real bonus.
As has been discussed in other threads, there are places where a microphone like this can be sent in and calibrated, giving the user a calibration curve to use with Room EQ Wizard or other such software packages, if not already supplied. Absent individual calibration, it could still be used to get rough starting-point curves for a system, but for any kind of refined work, individual calibration is a must.
Assuming basic performance specs like noise level and distortion are good, and there is no reason to believe they wouldn't be, this unit with its USB connection might be a nice measurement microphone for someone who doesn't have a good quality audio interface. Could be a real value unit for someone just getting into speaker/room measurements and treatments.
Edit: A correction about less-expensive measurement microphones and individual calibration curves - Dayton Audio's EMM-6 measurement microphone does come each with its own factory calibration curve. They retail for $80, Parts Express carries them for under $50, on sale at the moment of this writing for under $40, quite a deal, and the model appears to have very nice specifications overall. A unique text calibration file can be downloaded from Dayton's website corresponding to the microphone's serial number. The new UMM-6 is most likely (educated guess) based on the EMM-6, and as such may very well feature individual calibration files available, too.
AudiocRaver is offline
post #3 of 84 Old 11-25-12, 01:45 PM Thread Starter
Mike
Good point, we will have to wait until it is available to purchase and find out if it will come with a calibration file. I would certainly hope so with the price there asking.
One thing I remember about REW is you need to connect the audio output of your computer for the test tones. I wonder if it is possible to make a CD like Omnimic comes with so you only have to connect the USB mic and insert the CD and your ready to measure. This sure would make REW a lot more user friendly.
post #4 of 84 Old 11-25-12, 05:03 PM
Wayne Myers
sub_crazy wrote: View Post
I am not sure if REW needs to be generating the sweep in order to be "in sync" with it somehow, or if it can follow a sweep from any source and make proper sense of it. A good question for John, the programmer.
post #5 of 84 Old 11-30-12, 01:49 PM
REW Author
JohnM's Avatar
John
REW needs to generate the sweep itself presently, but the ability to measure with external sweeps is on my ToDo list.
MiniDSP have just come out with a new USB mic, UMIK-1, which is individually calibrated, see http://www.minidsp.com/products/acou...urement/umik-1. It's a neat package, I've tried out a prototype which works very well - all the benefits of a calibrated measurement mic without the hassle of needing a preamp with phantom power or having to go through soundcard calibration. I'm currently making some tweaks in REW to make measuring with the UMIK-1 even easier.
JohnM is offline
post #6 of 84 Old 11-30-12, 01:56 PM
Zeitgeist's Avatar
Jim
Nice to see some new simple USB mics.
Curious if calibrating them would be harder, as I imagine that calibrations for most mics that require phantom power actually use the raw signal from the mic..
John - Cool to see you tweaking REW for the MiniDSP mic.
Zeitgeist is offline
post #7 of 84 Old 12-01-12, 10:43 AM
just read the minidsp december newsletter and googled for the new umik-1 mic for any review or comparison with a professionally calibrated mics.
at USD$75 plus some shipping it should be the cheapest option to get a calibrated mic to use with REW. and it's specced to be flat till 5hz (after correction). by skipping phantom power, mic preamp or a new soundcard that supports condenser mic this should easily be the best deal so far.
i was previously considering the calibrated galaxy cm-140 (just to skip phantom power and mic pre) but after looking at the posted calibration result i decided to cancel. the meter have too much attenuation at the low frequency that it's not exactly precise anymore. -6db down at 20hz, -12db down at 10hz and -22db down at 5hz. it's only flat to 100hz.
this umik1 shows much potential. it's only a couple db down at 5hz.
paskal is offline
post #8 of 84 Old 12-01-12, 11:09 AM
I'm definitely in for more details. I haven't gotten around to picking up a USB-powered preamp, so this comes right at the right time.
94vg30de is offline
post #9 of 84 Old 12-01-12, 05:19 PM
REW Author
JohnM's Avatar
John
Another plus for the UMIK-1 is the cal file includes sensitivity calibration, which the next release of REW will use to provide calibrated SPL readings from the mic - no SPL meter needed.
JohnM is offline
post #10 of 84 Old 12-01-12, 05:46 PM
the only gripe is that there's no 90 degrees off axis correction.
if i remember correctly there should be some slight difference on axis and off axis measurement. higher attenuation at the high frequency.
paskal is offline
audio , dayton , mic , umm6 , usb
