Is the RS meter "good enough"? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 16 Old 03-26-13, 01:25 PM
tonyvdb's Avatar
Tony
Re: Is the RS meter "good enough"?
You should get one of these
Home theater:
Living room system:
tonyvdb is offline
post #12 of 16 Old 03-26-13, 01:54 PM
Wayne Myers
That would work.
The Q502 includes phantom power and a USB interface, eliminates the need for the UCA222, gives a much cleaner setup.
The ART USB dual pre is another good, simple option.
AudiocRaver is offline
post #13 of 16 Old 03-26-13, 01:58 PM
Macattack's Avatar
Okay, thanks! Yet another toy I have to purchase .
Theater -- Revel F52 and C32, B&W LM1, Lexicon MC1, McIntosh MC7106, Pioneer BD, Popcorn Hour, Direct TV, Panasonic Plasma
Two Channel -- Infinity Betas, RSIIa, McIntosh C2300, MC452, MC352, Shanling T-100MKIII, Sonos ZP90, Marantz SA8004, TT42
Macattack is offline
post #14 of 16 Old 03-26-13, 02:14 PM Thread Starter
3ll3d00d's Avatar
Matt
OK thanks. I suppose the q is when is an rs meter is not accurate enough for sub eq? Possibly this is a how long is a piece of string question. Do they drift at all?
Are there any issues with running a USB mic over a long (10m) cable? I have a feeling USB is limited to <5m or so.
Cheers
Matt
3ll3d00d is offline
post #15 of 16 Old 03-26-13, 02:42 PM
Wayne Myers
3ll3d00d wrote: View Post
Cheers
Matt
Here is one way of looking at it. Many home theater enthusiasts are looking for smooth subwoofer response, but not necessarily flat subwoofer response. Many home theater setups end up with subwoofer frequencies emphasized some amount above the rest of the frequency response curve as a matter of personal taste. The import thing is that it is done in a smooth, controlled fashion.
The RadioShack SPL meter with our generic calibration curve will do a good job of helping you achieve smooth response, which is definitely the main priority for good-sounding bass. Then you can adjust the amount of bass somewhat for personal taste by playing with the target curve in REW during the EQ process. If flat response is also a priority for some reason, or if there is a specific known target curve you want to achieve closely, then you need an individually calibrated measurement mic or SPL meter for that.
USB cable lengtht: 5 m is about the limit. Some devices, USB mics included, can work reliably with a buffered USB cable for extra length beyond that.
post #16 of 16 Old 03-28-13, 08:55 AM Thread Starter
3ll3d00d's Avatar
Matt
AudiocRaver wrote: View Post
that makes sense. Part of the reason I'm thinking about this is because I've recently seen what looks like audyssey producing a flat response that my spl meter measures as flat but +5-6dB higher (i.e. it looks a bit like a step down at 80Hz). I know there are various issues in measuring what audyssey has done with REW but it still looks quite odd.
3ll3d00d is offline
good enough , meter , rs
