Is the RS meter "good enough"? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 16 Old 03-26-13, 05:53 AM Thread Starter
3ll3d00d's Avatar
Matt
I'm getting back into REW after quite some time not fiddling with my system. The no of mics available seems to have exploded somewhat in the intervening time so I'm left wondering whether the RS meter can still be considered "good enough" for home use? i.e. subwoofer eq (currently BFD but likely moving to an inuke based system soon) & time alignment of mains/sub.
Alternatively what is the current recommended minimum/simple setup for this use (with subs that extend <15Hz)? I have no use for a mic apart from this & prices for mic/preamp in the UK seem to be rather more expensive than US prices.
I suspect this Q has been asked before but I can't find a clear answer in the many other threads around the subject.
Cheers
Matt
3ll3d00d is offline
post #2 of 16 Old 03-26-13, 08:37 AM
Wayne Myers
Re: Is the RS meter "good enough"?
The RS meters are pretty good for work between 100 hz and 3 Khz. There is a generic calibration file (LF correction only) on our downloads page that makes their accuracy better at lower frequencies, but the correction amount is around 40 db at 10 hz so real accuracy there would be suspect without individual calibration.
If you have have HDMI output from your computer for REW use, a USB mic (miniDSP UMIK-1 or Dayton UMM-6) is an easy way to get up and running. For calibrated accuracy below 20 hz, you will need one from Cross-Spectrum Labs, they calibrate down to 5 hz. If you are using analog out from your computer, you will need an analog mic (Cross-Spectrum Labs) and a calibratable sound card (see our database) for good LF accuracy.
Edit: If you just want to see that your LF response is "fairly smooth" down there, and are not really concerned about absolute accuracy, the RS meter with our generic calibration file will give you a good general picture.
AudiocRaver is offline
post #3 of 16 Old 03-26-13, 08:38 AM
tonyvdb's Avatar
Tony
If all your using the Radio Shack meter for is to take readings of the sub yes its good enough, if you want to get full range readings then you will need to move up to at least the Galaxy CM140 or even better a calibrated ECM8000
Home theater:
Living room system:
tonyvdb is offline
post #4 of 16 Old 03-26-13, 10:12 AM
Macattack's Avatar
tonyvdb wrote: View Post
I would like to build on the the OP's question. I am in the middle of learning the REW tool, have an RS SPL meter \ Behringer UCA222 \ Laptop setup and am 'making measurements' moving speakers around. I do want to get full range measures to support more ROOM tuning and am looking for how best to do that.
-- The mics you list above seem to use XLR connections but the UCA 222 uses RCA. Can I use an adapter to go 'down' to an RCA for my UCA222 DAC?
Or more directly, what MIC options would work best with the UCA222? I also will use this mic only for this purpose - measuring and optimizing my theater and 2 channel rooms.
TIA
Macattack is offline
post #5 of 16 Old 03-26-13, 10:29 AM
tonyvdb's Avatar
Tony
The issue is that you need a calibration file for the mic your using. The ECM 6000 and 8000 are the only stand alone mic's that have these available (you can make files for other mic's but you need the detailed specifications for the mic). The Galaxy CM140 is a SPL meter thats better than the RS meter but its still only good up to 12k at best.
Home theater:
Living room system:
tonyvdb is offline
post #6 of 16 Old 03-26-13, 10:33 AM
Macattack's Avatar
Thank you. Sounds like with an ECM8000 (~$60) and an XLR to RCA adapter, I am good to go! That is clear.
post #7 of 16 Old 03-26-13, 10:34 AM
tonyvdb's Avatar
Tony
You will need a phantom power supply to use the 8000 as well.
Home theater:
Living room system:
tonyvdb is offline
post #8 of 16 Old 03-26-13, 12:55 PM
Macattack's Avatar
Macattack wrote: View Post
Placing my order on Amazon ---- Quick question. Which XLR to RCA adapter do I need from the ECM8000 XLR output to my UCA222 RCA input?
FEMALE to RCA or MALE to RCA?
post #9 of 16 Old 03-26-13, 01:22 PM
tonyvdb's Avatar
Tony
You first need to have a phantom power supply for the mic. You cant just "convert" the XLR to rca without a proper transformer. You are essentially going form Balanced to unbalanced.
Home theater:
Living room system:
tonyvdb is offline
post #10 of 16 Old 03-26-13, 01:24 PM
Wayne Myers
Hold that order...
The UCA222 is not a mic preamp. You need a mic preamp. A preamp will accept the XLR and will supply phantom power. And lots of gain. The UCA222 will not work with a mic input directly.
good enough , meter , rs
