Tascam US-144 MKII Digital Out Produces No Test Tones - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 22 Old 01-29-14, 09:36 PM Thread Starter
I am using Tascam US-144 MKII. I have successfully calibrated the sound card with the loopback connection. I have the following questions:
1) At REW's Sound Card Calibration page, I tired to lower the level with the "Control output mixer/volume box" in REW, but it is grey out! How can I turn this option on?
2) I have a problem trying to measure the output with my Nuforce AVP-18 preamp which only accepts digital input such as for Coaxial or Optical. After I connected a coaxial cable from Tascam US-144's digital-out to AVP-18's digital-in then pressed check levels button, my AV system did not produce any tone. I have checked all connections and setting in AVP-18, and they are correct. Is there any switch in Tascam US-144 I need to turn on in order to use its digital in/out? Can I actually use Tascam US-144's digital out for this type of connection? Has anyone tried this configuration successfully for REW measurement? Please advise!
Many thanks in advance!!
RingoHung is offline
post #2 of 22 Old 01-30-14, 07:38 AM
Re: Tascam US-144 MKII Digital Out Produces No Test Tones
1) You don't need ( software based ) control of the output volume ( ie; from within REW ) since the 144 has a hardware based solution for you to use ( called , the "Line Out" knob on the card itself ) .
2) Your 4-chnl soundcard ( by default ) has the Coax ( SPDIF ) connector, outputting channels 3 & 4 // meaning that you'll need to "re-configure" the SPDIF to instead output chnls 1 & 2 ( this is accomplished from within the Tascam sound control panel ) .
I'd suggest a thorough read of the Operators Manual since it will tell you how to make the necessary changes ( as well as "what does what" ) .
EarlK is offline
post #3 of 22 Old 02-02-14, 09:30 AM Thread Starter
Thanks for your response! I have indeed tried this before that set the digital out as Ch 1 and Ch2. Unfortunately, I didn't work.....
post #4 of 22 Old 02-03-14, 03:11 PM
REW Author
JohnM's Avatar
John
Try using the Tascam's ASIO drivers and REW V5.01 beta.
JohnM is online now
post #5 of 22 Old 02-06-14, 03:27 AM Thread Starter
Thanks for your advice! Will try tonight!
post #6 of 22 Old 02-23-15, 01:53 PM
Tim
Where does one acquire Tascam's ASIO drivers?
They weren't in the software drivers included with the US-144 MKII....
loach71 is offline
post #7 of 22 Old 02-23-15, 04:57 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Have you tried TASCAM's web site?
post #8 of 22 Old 02-24-15, 10:45 AM
Tim
No link on the TASCAM website for the ASIO drivers.
Maybe ASIO4ALL is a good alternative?
loach71 is offline
post #9 of 22 Old 02-24-15, 04:53 PM
REW Author
JohnM's Avatar
John
The ASIO drivers get installed as part of the Windows driver package. I've found the US-144MkII pretty temperamental though, it was fine on XP but doesn't seem to like Win 7 or Win 8 very much, does odd things on input levels from time to time and I find I have to quit and restart the driver (by restarting REW) after changing sample rates when using ASIO or it doesn't work at all. Might just be my unit.
JohnM is online now
post #10 of 22 Old 02-24-15, 05:17 PM
Tim
John:
I am noting the same flakiness on the US-144 MkII on my Win7 x64 setup.
No repsonse yet from TASCAM tech support...
Time for another sound card?
loach71 is offline
digital , mkii , produces , tascam , test , tones , us144
