Unable to calibrate sound card - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 3 Old 09-01-14, 07:10 PM Thread Starter
New Member
Hi all I am new to this forum and recently downloaded REW to help measure my studio acoustics. To prepair for the soundcard calibration I connected a balanced 1/4 inch cable from input to output of line 1 in Apollo. I switched the output of Apollo's console to line 1 and started the calibration. I can hear and see the test tone in the output but can't get a reading on the left or right side to match to. I have tried different sample rates and everything I can think of inside of windows and can't get it to work. Any suggestions?
Windows 8.1 Intel i7-3770 3.4ghz 16gb ram 64 bit, sound card UAD Apollo, behringer ECM 8000.
paulisher is offline
post #2 of 3 Old 09-02-14, 08:35 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Unable to calibrate sound card
Which Apollo product are you using? Probably should use an unbalanced TS cable instead, as often the 1/4” inputs on interfaces are unbalanced.
That said, it probably doesn’t matter if you are able to get a sound card calibration. Most interfaces as cheap as $100-150 have ruler flat response, so I’d expect nothing less of Apollo. With native response that good, no calibration is needed.
post #3 of 3 Old 09-02-14, 08:57 PM Thread Starter
New Member
Thanks Wayne,
My interface is the first UAD Apollo which in 8 in and 8 out with 4 mic pre's. I guess I just got stuck in the soundcard calibration as I thought this was where to start. I thought I needed to balance the input and the output with calibration before I took any measurements with my mic. By the way I used both balanced and TS unbalanced cables with the same result. It occurred though that I was attempting to loop back in and out of channel 1 and perhaps I should loop the insert of channel 1 to the main output of Apollo.
Paul
calibrate , card , sound , unable
