-   SPL Meters | Mic's | Calibration | Sound Cards (https://www.hometheatershack.com/forums/spl-meters-mic-s-calibration-sound-cards/)
-   -   Software Crossover with Xonar DGX (https://www.hometheatershack.com/forums/spl-meters-mic-s-calibration-sound-cards/167474-software-crossover-xonar-dgx.html)
StabMe 03-30-17 09:31 AM
Hey!
The question is related to a soundcard feature, so i iope i am posting in a right section.
I have a Asus Xonar DGX sound card, which is pce-e based, 5.1 card. I want to use it to set up a 2.1 system. I have a stereo speaker system with its own integrated amp and a subwoofer with an amp. Both do not have crossovers in them. So i decided to use this card to set up a crossover and on top of that use some room correction EQing.
I installed VSThost to do the crossover/eq thing, but i can only find one stereo output channel while i expected to see 3 pairs, since it is a 5.1 card. Before that, i used M-Audio FireWire 410 and i was always able to use any of its outputs from a DAW software. I guess, i am missing something about cheap consumer grade 5.1 cards.
My question is - is there a way i can use at least 4 channels inside a software similar to VSTHost and send different sound to those channels? Or should switch to another card?
On another hand, there is a dedicated LFE/Ctr output in that card. Maybe, i somehow can use that output for my 2.1 setup? Simply setup a crossover through a software that comes with the card?
RTS100x5 06-05-17 09:02 AM
Re: Software Crossover with Xonar DGX
My guess is that the soundcard driver needs to support ASIO...try downloading the free ASIO driver and experiment with that
http://www.asio4all.com/
RTS100x5 06-05-17 09:20 AM
Also consider using JRIVER as a media streaming software - It has massive support and tweaks for multichannel speaker systems...
