-   SPL Meters | Mic's | Calibration | Sound Cards (https://www.hometheatershack.com/forums/spl-meters-mic-s-calibration-sound-cards/)
-   -   Looking for advice on Boom Mic (https://www.hometheatershack.com/forums/spl-meters-mic-s-calibration-sound-cards/172218-looking-advice-boom-mic.html)
rimmi2002 11-21-17 08:48 PM
Hi I am setting things up for Rew measurements. I already have the UMIK mic. reading through the instructions I saw that I also need a boom mic.
Will this one: On Stage Stands MS7701B Tripod Boom Microphone Stand work well? It is from Amazon. Sorry I can post links right now.
Or is there another one recommended?
The_Nephilim 11-21-17 09:42 PM
Re: Looking for advice on Boom Mic
Yes I do believe that will work.. It should work with any mic stand ;)
rimmi2002 11-22-17 01:00 AM
The UMIK came with a small stand on a tripod. will that work also? The REW guide recommended not just placing that on the couch by itself.
Kal Rubinson 11-22-17 07:55 AM
rimmi2002 wrote: (Post 1596570)
If that is what I got, it is nearly useless. Its adjustability is extremely limited and cannot be used on anything other than a hard flat surface.
The_Nephilim 11-23-17 03:44 AM
yes that stand is useless as it states in the guide not to put on the couch or chair.. a Boom mic is Highly recommended..
The_Nephilim 11-23-17 03:45 AM
yes that little stand is useless as it states in the guide not to put on the couch or chair.. a Boom mic is Highly recommended..
rimmi2002 11-23-17 12:42 PM
The_Nephilim wrote: (Post 1596618)
Thanks. I ordered the one from Amazon listed above. In the reviews someone mentioned they used it for the umik
