-   SPL Meters | Mic's | Calibration | Sound Cards (https://www.hometheatershack.com/forums/spl-meters-mic-s-calibration-sound-cards/)
-   -   SVSound AS-EQ1 Mic calibration file (https://www.hometheatershack.com/forums/spl-meters-mic-s-calibration-sound-cards/22699-svsound-eq1-mic-calibration-file.html)
ccdoggy 11-09-09 10:19 AM
I will have a new AS-EQ1, eventually on its way, and am wondering if there is a calibration file for the included mic. I was thinking that maybe its a commonly used mic that i could use to measure the differences made by the EQ and other changes to my room.
The other 'mic' i have is the old RS analog meter, which works fine but it would be nice if i could use the new mic.
So is there a Cal file out there for it? is it a generic of some other mic that has a cal file?
Thanks!
Wayne A. Pflughaupt 11-09-09 11:33 AM
Re: SVSound AS-EQ1 Mic calibration file
It's an Audyssey-specific mic. The calibration will be built into the AS-EQ1; as such there is no compelling reason for them to publish a calibration file.
ccdoggy 11-09-09 02:44 PM
aah, well then what would you think about using the AS-EQ1 in mic pass-through. would it apply the calibration tweaks to the signal exiting the unit from the passthrough mic output? I kinda feel like it would not, but worth an ask.
