Axiom EP800 - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 4 Old 10-02-12, 08:48 AM Thread Starter
Dale Rasco's Avatar
Dale Rasco
Axiom EP800
Manufacturer Specs:
Spoiler
Enclosure: Sealed / Acoustic Suspension
RMS Amp Power: 800 Watts
Crossover Adjust 40, 60, 80, 100 & 150 Hz
Phase 0 & 180
Woofer Size two 12-inch
High Powered DSP Engine Yes
Line In and Out Yes
Balanced Line In and Out Yes
High Level In Yes
Subsonic Filter Yes, On (20 Hz), Off (12 Hz)
Dynamic Power Supply Yes
Anechoic Resp. +/- 1dB 13 - 150 Hz Frequency Graph
Anechoic Resp. +/- 3dB 12 - 150 Hz
Max SPL Anechoic 114 dB
Max SPL In Room 120 dB
Dimensions HWD (WHD for Horizontal): 1156 x 381 x 432 mm
Dimensions HWD (WHD for Horizontal) : 45˝ x 15 x 17 inches
Weight lbs each: 110 lbs
Weight kg each: 49.9 kgs
Manufacturers Published Measurements
HTS Results
Setup Images
Frequency Response
Max Output Before Compression
Spectral Decay
Group Delay
Waterfall
Spectrogram
Harmonic Distortion
Click the Spoiler button for the REW notes from each individual frequency
Spoiler
32 Hz
65536-point spectrum using Rectangular window and no averaging
Input RMS 103.0 dB
Distortion at 31.6 Hz, -7.2 dB FS based on 8 harmonics:
THD 5.0284 %
THD+N 13.1355 %
2nd harmonic 4.9972%
3rd harmonic 0.4458%
4th harmonic 0.2285%
5th harmonic 0.2086%
6th harmonic 0.0802%
7th harmonic 0.0744%
8th harmonic 0.0544%
9th harmonic 0.0628%
40 Hz
Input RMS 103.1 dB
Distortion at 39.9 Hz, -7.1 dB FS based on 8 harmonics:
THD 2.2046 %
THD+N 15.6482 %
2nd harmonic 1.9777%
3rd harmonic 0.6972%
4th harmonic 0.4129%
5th harmonic 0.3148%
6th harmonic 0.2657%
7th harmonic 0.2425%
8th harmonic 0.1928%
9th harmonic 0.1642%
50 Hz
Input RMS 102.0 dB
Distortion at 49.9 Hz, -8.2 dB FS based on 8 harmonics:
THD 2.2402 %
THD+N 13.0637 %
2nd harmonic 2.1101%
3rd harmonic 0.6670%
4th harmonic 0.2629%
5th harmonic 0.1870%
6th harmonic 0.0675%
7th harmonic 0.0865%
8th harmonic 0.0523%
9th harmonic 0.0464%
63 Hz
Input RMS 102.5 dB
Distortion at 63.1 Hz, -7.7 dB FS based on 8 harmonics:
THD 2.6024 %
THD+N 8.1164 %
2nd harmonic 2.3749%
3rd harmonic 0.8504%
4th harmonic 0.3826%
5th harmonic 0.2827%
6th harmonic 0.2589%
7th harmonic 0.2201%
8th harmonic 0.1993%
9th harmonic 0.1661%
70 Hz
Input RMS 100.3 dB
Distortion at 70.0 Hz, -9.9 dB FS based on 8 harmonics:
THD 2.7564 %
THD+N 5.9002 %
2nd harmonic 2.6486%
3rd harmonic 0.7406%
4th harmonic 0.1225%
5th harmonic 0.1316%
6th harmonic 0.0222%
7th harmonic 0.0212%
8th harmonic 0.0138%
9th harmonic 0.0235%
80 Hz
Input RMS 100.8 dB
Distortion at 80.1 Hz, -9.5 dB FS based on 8 harmonics:
THD 2.1557 %
THD+N 12.7745 %
2nd harmonic 2.0456%
3rd harmonic 0.6447%
4th harmonic 0.1277%
5th harmonic 0.1100%
6th harmonic 0.0839%
7th harmonic 0.0701%
8th harmonic 0.0589%
9th harmonic 0.0541%
Check out the EP800 at Axiom
Dale Rasco
“Opportunity is missed by most people because it is dressed in overalls and looks like work." -Thomas A. Edison
Dale Rasco and
Dale Rasco is offline
post #2 of 4 Old 10-11-12, 09:27 PM
HTS Moderator
Reviewer
theJman's Avatar
Jim
Re: Axiom EP800
Wow, that's a very impressive showing (well, except for the part where it measures almost 4 feet tall ). Bet that sounded real nice.
-Jim
theJman is offline
post #3 of 4 Old 11-01-12, 09:58 PM
Re: Axiom EP800
Nice review Dale. Compression testing is a great addition to the reviews. It really helps to show the system's capability!
Archaea is offline
post #4 of 4 Old 11-23-12, 01:45 PM
New Member
Re: Axiom EP800
I like my Axiom products.. Nice set of data. Did you have an agreement with the neighbours to stay inside during this? LOL
everlast is offline
axiom , ep800
