KREISEL DXD808 - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 4 Old 11-27-12, 04:31 PM Thread Starter
Dale Rasco's Avatar
Dale Rasco
KREISEL DXD808
KEN KREISEL DXD808
Specifications
Driver Configuration
DUAL PUSH-PULL 8” HIGH VELOCITY DEEP BASS DRIVERS
Typical in Room Frequency Response
15 Hz - 200 Hz
Variable Phase Adjustment
0 to 180 degrees
Variable Low Pass Filter
Range: 40Hz - 160Hz at 12db per Octave
Variable Bass Level
with Switched Calibrated Reference Level Setting
Variable Low Pass
Filter Bypass Switch
Auto On/Off switch
Only operates when using the RCA inputs
Unbalanced RCA LFE/Line Inputs
Impedance for Unbalanced RCA Inputs
8k Ohms
Balanced XLR Input
1
Impedance for Balanced XLR Inputs
30k Ohms
Impedance for XLR Input connected unbalanced from Pin 2 to Ground
15k Ohms
Balanced XLR Direct Pass-Thru (Unbuffered)
1
Manufacturers Published Measurements
N/A
Frequency Response
Max Output Before Compression
Spectral Decay
Group Delay
Waterfall
Spectrogram
Harmonic Distortion
Click the Methods button for the REW notes from each individual frequency
Measurement Methods
20 Hz
65536-point spectrum using Rectangular window and no averaging
Input RMS 83.7 dB
Distortion at 20.1 Hz, -30.9 dB FS based on 8 harmonics:
THD 11.2143 %
THD+N 26.0632 %
2nd harmonic 5.6877%
3rd harmonic 9.5453%
4th harmonic 0.9475%
5th harmonic 0.9386%
6th harmonic 0.4914%
7th harmonic 0.2914%
8th harmonic 0.3120%
9th harmonic 0.3076%
25 Hz
Input RMS 88.5 dB
Distortion at 24.9 Hz, -26.0 dB FS based on 8 harmonics:
THD 9.2228 %
THD+N 15.0937 %
2nd harmonic 5.1339%
3rd harmonic 7.5870%
4th harmonic 0.7837%
5th harmonic 0.5749%
6th harmonic 0.2419%
7th harmonic 0.2095%
8th harmonic 0.2315%
9th harmonic 0.1948%
31.5 Hz
Input RMS 93.6 dB
Distortion at 31.6 Hz, -22.4 dB FS based on 8 harmonics:
THD 9.1120 %
THD+N 57.6074 %
2nd harmonic 4.7997%
3rd harmonic 7.6451%
4th harmonic 0.9887%
5th harmonic 0.5971%
6th harmonic 0.3290%
7th harmonic 0.2195%
8th harmonic 0.1665%
9th harmonic 0.1617%
40 Hz
Input RMS 99.7 dB
Distortion at 39.9 Hz, -14.7 dB FS based on 8 harmonics:
THD 10.1247 %
THD+N 16.4040 %
2nd harmonic 6.4556%
3rd harmonic 7.6421%
4th harmonic 1.1048%
5th harmonic 0.6741%
6th harmonic 0.5575%
7th harmonic 0.5094%
8th harmonic 0.3398%
9th harmonic 0.2667%
50 Hz
Input RMS 104.9 dB
Distortion at 49.9 Hz, -9.5 dB FS based on 8 harmonics:
THD 5.2239 %
THD+N 10.9293 %
2nd harmonic 1.8386%
3rd harmonic 4.0353%
4th harmonic 2.0458%
5th harmonic 1.4452%
6th harmonic 0.7827%
7th harmonic 0.7592%
8th harmonic 0.3602%
9th harmonic 0.1780%
63 Hz
Input RMS 105.1 dB
Distortion at 63.1 Hz, -9.3 dB FS based on 8 harmonics:
THD 5.9377 %
THD+N 10.6554 %
2nd harmonic 2.3170%
3rd harmonic 4.5823%
4th harmonic 1.6383%
5th harmonic 2.2715%
6th harmonic 0.9247%
7th harmonic 0.3699%
8th harmonic 0.1694%
9th harmonic 0.1616%
80 Hz
Input RMS 106.7 dB
Distortion at 80.1 Hz, -7.6 dB FS based on 8 harmonics:
THD 3.5747 %
THD+N 4.9429 %
2nd harmonic 2.2490%
3rd harmonic 1.9886%
4th harmonic 1.2949%
5th harmonic 1.3914%
6th harmonic 0.3451%
7th harmonic 0.0750%
8th harmonic 0.1198%
9th harmonic 0.1175%
Dale Rasco
“Opportunity is missed by most people because it is dressed in overalls and looks like work." -Thomas A. Edison
Dale Rasco and
Dale Rasco is offline
post #2 of 4 Old 02-11-13, 11:40 PM
Dan
Re: KREISEL DXD808
An 8" woofer is doing that? WOW!
DanTheMan is offline
post #3 of 4 Old 12-09-13, 04:08 PM
DanTheMan wrote: View Post
No 2 8 inch woofers are.
Sent from my GT-I9505 using HT Shack
scottthehat is offline
post #4 of 4 Old 12-09-13, 05:55 PM
asere's Avatar
Yes all that is right. I own the big brother DDS 12012 thanks to the Shack since they gave me the opportunity to win it.
The sub is amazing and clean sounding!!
asere is offline
dxd808 , kreisel
