GR Research FG12 Servo - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 11-27-12, 04:32 PM Thread Starter
Dale Rasco's Avatar
Dale Rasco
Specifications
Driver
12" high excursion with custom sensing coil
Driver materials
Treated paper with foam surround
Cast aluminum basket
Amplifier
370w RMS class A/B patented servo controlled
Dimensions
15-3/4"(W) x 15-3/4" (H )x 17"(D) - (18-1/2" D with grille)
Shipping Weight
80 lbs
Frequency Response
14 - 100 Hz (-2 dB @ 14 Hz)
Crossover slope
Selectable 12 or 24 dB / octave (PEQ and XLR versions)
Crossover range (Low pass)
25 - 120 Hz
Rumble Filter (High pass )
20Hz 18 dB / octave
Phase response
90 degrees phase shift at 20 Hz
Phase adjustment
0 - 180 degrees continuously variable
Bass damping factor settings
high (Q=0.5), med (Q=0.7), and low (Q=1.1)
Finishes
Available in honey oak vinyl or black oak vinyl
(Piano Gloss available in signature edition only)
Warranty
5 years warranty on driver and 2 years on electronics
30 day satisfaction guarantee
Manufacturers Published Measurements
Frequency Response
Max Output Before Compression
Spectral Decay
Group Delay
Waterfall
Spectrogram
Harmonic Distortion
Click the Methods button for the REW notes from each individual frequency
Measurement Methods
16 Hz
65536-point spectrum using Rectangular window and no averaging
Input RMS 84.5 dB
Distortion at 16.1 Hz, -22.8 dB FS based on 8 harmonics:
THD 10.5386 %
THD+N 45.1665 %
2nd harmonic 9.4535%
3rd harmonic 3.5828%
4th harmonic 2.0572%
5th harmonic 1.4599%
6th harmonic 0.6421%
7th harmonic 0.9423%
8th harmonic 0.4653%
9th harmonic 0.9884%
20 Hz
Input RMS 86.2 dB
Distortion at 20.1 Hz, -20.4 dB FS based on 8 harmonics:
THD 10.2556 %
THD+N 24.5709 %
2nd harmonic 9.4107%
3rd harmonic 3.0110%
4th harmonic 1.8900%
5th harmonic 1.2771%
6th harmonic 0.5557%
7th harmonic 1.1824%
8th harmonic 0.4066%
9th harmonic 0.6893%
25 Hz
Input RMS 92.4 dB
Distortion at 24.9 Hz, -15.3 dB FS based on 8 harmonics:
THD 10.0319 %
THD+N 52.2727 %
2nd harmonic 9.4164%
3rd harmonic 2.3197%
4th harmonic 1.4482%
5th harmonic 1.4030%
6th harmonic 0.6853%
7th harmonic 1.1188%
8th harmonic 0.4571%
9th harmonic 0.7698%
31.5 Hz
Input RMS 95.2 dB
Distortion at 31.6 Hz, -11.3 dB FS based on 8 harmonics:
THD 9.4596 %
THD+N 20.4769 %
2nd harmonic 8.9471%
3rd harmonic 2.4688%
4th harmonic 0.8406%
5th harmonic 1.2487%
6th harmonic 0.1981%
7th harmonic 0.8678%
8th harmonic 0.2203%
9th harmonic 0.4807%
40 Hz
Input RMS 101.9 dB
Distortion at 39.9 Hz, -4.5 dB FS based on 8 harmonics:
THD 8.2066 %
THD+N 18.0393 %
2nd harmonic 7.9316%
3rd harmonic 1.2407%
4th harmonic 1.0503%
5th harmonic 0.9829%
6th harmonic 0.1959%
7th harmonic 0.7569%
8th harmonic 0.1446%
9th harmonic 0.4440%
50 Hz
Input RMS 102.5 dB
Distortion at 49.9 Hz, -4.1 dB FS based on 8 harmonics:
THD 6.5836 %
THD+N 26.3948 %
2nd harmonic 3.3385%
3rd harmonic 3.7088%
4th harmonic 2.0987%
5th harmonic 2.5738%
6th harmonic 1.5131%
7th harmonic 1.8636%
8th harmonic 0.8310%
9th harmonic 0.9803%
63 Hz
Input RMS 102.4 dB
Distortion at 63.1 Hz, -4.0 dB FS based on 8 harmonics:
THD 7.0776 %
THD+N 20.1273 %
2nd harmonic 4.7077%
3rd harmonic 2.0823%
4th harmonic 2.2461%
5th harmonic 2.0191%
6th harmonic 1.8041%
7th harmonic 2.1711%
8th harmonic 1.7517%
9th harmonic 1.8533%
80 Hz
Input RMS 102.6 dB
Distortion at 80.1 Hz, -3.8 dB FS based on 8 harmonics:
THD 3.5731 %
THD+N 7.9012 %
2nd harmonic 3.5252%
3rd harmonic 0.4400%
4th harmonic 0.1775%
5th harmonic 0.1740%
6th harmonic 0.1514%
7th harmonic 0.1439%
8th harmonic 0.1396%
9th harmonic 0.1448%
Dale Rasco
“Opportunity is missed by most people because it is dressed in overalls and looks like work." -Thomas A. Edison
Dale Rasco and
Dale Rasco is offline
post #2 of 8 Old 12-03-12, 02:51 PM
pharoah's Avatar
Re: GR Research FG12 Servo
thats the 12 inch rythmik with the gr driver correct?
pharoah is offline
post #3 of 8 Old 12-03-12, 03:27 PM Thread Starter
Dale Rasco's Avatar
Dale Rasco
That is correct but I need to add some additional measurements based on the filter settings, etc. just wanted to make sure that I mentioned that. I should have those up later today or tomorrow.
Dale Rasco
Dale Rasco and
post #4 of 8 Old 12-03-12, 05:48 PM
pharoah's Avatar
cool cant wait to see the addotional info.
pharoah is offline
post #5 of 8 Old 12-03-12, 06:03 PM Thread Starter
Dale Rasco's Avatar
Dale Rasco
I'll be doing the same thing for the Rythmik 15 and the SVS PB13 Ultra as well.
Dale Rasco
Dale Rasco and
post #6 of 8 Old 04-22-13, 09:02 AM
Are some of the images down?
follz is offline
post #7 of 8 Old 01-07-14, 09:37 AM
Blacklightning's Avatar
follz wrote: View Post
seems like Frequency Response and Max Output Before Compression are missing.
You can see the frequency response in the Harmonic Distortion graph (I think)
Blacklightning is offline
post #8 of 8 Old 01-17-14, 10:01 PM
Dale, can you repost the Frequency response and Max Compression charts for this sub?
Knowing that this sub is not a SPL monster, how does this sub compare with other 12" driver subs?
padgman1 is offline
fg12 , gr , research , servo
