-   The Sub Zone (Subwoofer Testing) (https://www.hometheatershack.com/forums/sub-zone-subwoofer-testing/)
-   -   SVSound SB13 Ultra (https://www.hometheatershack.com/forums/sub-zone-subwoofer-testing/62090-svsound-sb13-ultra.html)
Dale Rasco 10-02-12 08:55 AM
SVSound SB13 Ultra
Read the full review here
Manufacturer Specs:
Spoiler
Subwoofer Specs:
  • Cabinet Dims: 17.4" (H) x 17.4" (W) x 17.4"(D)
  • Overall Dims: 17.9" (H) x 17.4" (W) x 20.4"(D)(includes feet, grille, amplifier)
  • Weight: 92 pounds
  • Rigid and braced MDF cabinet
  • Piano gloss black and real black oak veneer finish options
  • Front-firing driver
  • Protective non-resonant steel mesh grille
Driver Specs:
  • SVS 13.5” high-performance Ultra driver optimized for sealed applications
  • SVS custom-tooled die-cast aluminum basket
  • Flat-wire, 3” diameter, high-power, high-temp, 8-layer, aluminum voice coil - unique to SB13-Ultra
  • Polyimide impregnated fiberglass former/bobbin
  • Dual 9", composite layered, linear roll, extreme excursion spiders
  • Integrated tinsel leads
  • Nickel-plated high-tension spring terminals
  • Proprietary injection molded gasket and parabolic SBR extreme-excursion surround
  • Composite pulp/fiberglass press layered cone with stitched surround
  • Low carbon 1008 steel components, electrophoresis black plating
  • FEA-optimized overhung motor structure with custom gap extension plate enhances force/displacement symmetry, lower distortion and increases linear stroke
  • Copper shorting sleeve reduces gap induction and distortion, and enhances thermal conductivity
  • Dual Genox 8H/Y-35 high grade ferrite magnets
  • Oversized pole vent for greater cooling and low noise
Amp Specs:
  • STA-1000D Sledge with 1000 watts RMS continuous power (3600 watts peak dynamic power)
  • High efficiency cool-running Class D switching topology
  • Detachable power cord with main power switch and ceramic fuse
  • RoHS compliant, lead-free construction and world-wide safety certifications
  • Auto-On / On switch with "green" standby mode
  • Stereo line-level RCA and balanced (XLR) I/O connections
  • Normal and Hi input voltage switch
  • Customized EQ and DSP limiter settings specifically for the SB13-Ultra
  • Fully adjustable (frequency and slope) phase-correct speaker/sub digital crossover
  • Intelligent Feature Control (IFC) with bright LCD display
  • Two (2) digital PEQs with adjustable frequency, cut/boost, and Q values
  • Room gain compensation control with adjustable frequency and slope
  • Adjustable digital delay on main speaker line-level outputs to time-align the speakers and subs
Manufacturers Published Measurements
http://www.hometheatershack.com/gallery/file.php?n=9479
HTS Results
Setup Images
http://www.hometheatershack.com/gallery/file.php?n=9602
http://www.hometheatershack.com/gallery/file.php?n=9601
http://www.hometheatershack.com/gallery/file.php?n=9600
Frequency Response
Manufacturer Match
http://www.hometheatershack.com/gallery/file.php?n=9491
Sub Zone Methodology
http://www.hometheatershack.com/gallery/file.php?n=9663
Max Output Before Compression
http://www.hometheatershack.com/gallery/file.php?n=9495
Spectral Decay
http://www.hometheatershack.com/gallery/file.php?n=9662
Group Delay
http://www.hometheatershack.com/gallery/file.php?n=9664
Waterfall
http://www.hometheatershack.com/gallery/file.php?n=9684
Spectrogram
http://www.hometheatershack.com/gallery/file.php?n=9666
Harmonic Distortion
http://www.hometheatershack.com/gallery/file.php?n=9711
Click the Spoiler button for the REW notes from each individual frequency
Spoiler
32 Hz
65536-point spectrum using Rectangular window and no averaging
Input RMS 107.0 dB
Distortion at 32.1 Hz, -5.3 dB FS based on 8 harmonics:
THD 8.3285 %
THD+N 17.5815 %
2nd harmonic 5.6322%
3rd harmonic 5.9698%
4th harmonic 0.8301%
5th harmonic 0.6636%
6th harmonic 0.4609%
7th harmonic 0.5437%
8th harmonic 0.4142%
9th harmonic 0.4405%
40 Hz
Input RMS 108.2 dB
Distortion at 39.9 Hz, -4.4 dB FS based on 8 harmonics:
THD 5.8492 %
THD+N 33.4584 %
2nd harmonic 3.6352%
3rd harmonic 2.3755%
4th harmonic 2.2460%
5th harmonic 2.1495%
6th harmonic 1.5320%
7th harmonic 1.2049%
8th harmonic 1.0857%
9th harmonic 0.8442%
50 Hz
Input RMS 107.9 dB
Distortion at 49.9 Hz, -4.3 dB FS based on 8 harmonics:
THD 1.9054 %
THD+N 7.3711 %
2nd harmonic 1.2633%
3rd harmonic 1.1979%
4th harmonic 0.5060%
5th harmonic 0.3659%
6th harmonic 0.2960%
7th harmonic 0.2151%
8th harmonic 0.1966%
9th harmonic 0.1933%
63 Hz
Input RMS 107.9 dB
Distortion at 63.1 Hz, -4.3 dB FS based on 8 harmonics:
THD 1.8390 %
THD+N 9.5475 %
2nd harmonic 1.0654%
3rd harmonic 1.3481%
4th harmonic 0.4337%
5th harmonic 0.3346%
6th harmonic 0.2083%
7th harmonic 0.1900%
8th harmonic 0.1538%
9th harmonic 0.1619%
70 Hz
Input RMS 108.0 dB
Distortion at 70.0 Hz, -4.2 dB FS based on 8 harmonics:
THD 1.6726 %
THD+N 11.5492 %
2nd harmonic 0.9928%
3rd harmonic 1.3247%
4th harmonic 0.1420%
5th harmonic 0.1762%
6th harmonic 0.0115%
7th harmonic 0.0669%
8th harmonic 0.0326%
9th harmonic 0.0135%
80 Hz
Input RMS 107.9 dB
Distortion at 80.1 Hz, -4.4 dB FS based on 8 harmonics:
THD 2.1694 %
THD+N 18.9441 %
2nd harmonic 1.2177%
3rd harmonic 0.8941%
4th harmonic 0.6427%
5th harmonic 0.8876%
6th harmonic 0.5434%
7th harmonic 0.6853%
8th harmonic 0.4279%
9th harmonic 0.5244%
acoustat6 10-29-12 10:59 AM
Re: SVSound SB13 Ultra
Hi Dale, Nice attempt to measure this woofer. But I unfortunately have to say I don't believe that your measurements are correct. I use REW and have a bit of experience measuring speakers and I am quite suspect at the Freq response and the waterfall do not look realistic at all. Way too flat and smooth.
Bob
Dale Rasco 10-29-12 11:18 AM
Hi Bob, I appreciate your feedback. There are plenty of variables that could lead to the smoothness of a response for instance; I am not sure what type of mic and pre-amp you are using and also do not know what type of testing environment you used. I am also unsure of which response you are referring. The response in my results are less smooth than the one that SVS has listed on their own site which is the very first graph listed.
acoustat6 10-29-12 11:48 AM
Hi Dale, "There are plenty of variables that could lead to the smoothness of a response for instance"
You got that right. But looking at the other freq response that you posted, they all look wrong/incorrect/impossible. Sorry thats the way I see it.
Bob
PHP143
"Make progress, not excuses"
Sorry had to borrow that tag line
acoustat6 10-29-12 12:06 PM
Hi Dale, thanks again for you effort, are you able to post the mdat?
Thanks,
Bob
acoustat6 10-29-12 12:16 PM
Hi Dale, Aso,how about measuring and posting graphs according to the accepted and standard REW graph "standards". IE measure at 75db and post the graphs with the standard 45-105db and 20 to 200hz.
Thanks
Bob
Sonnie 10-29-12 12:31 PM
The responses look very similar to all the other responses I see for outdoor sub measuring, including what Ilkka did and what Josh is doing. They are far from "impossible".
Granted we probably do need some consistency for the graph settings.
VERTICAL = 45dB-105dB
HORIZONTAL = 15Hz-200Hz.
This is the standard for helping others with their home response in the REW Forum. That is not feasible for all of the testing measurements here, but we could easily include one for comparison, yet I would recommend 10Hz-200Hz, because there are many viewers who want to see the lower end.
Dale Rasco 10-29-12 12:38 PM
That is something I had not considered Sonnie and given that the SB13 has a response up to 460z, I should have kept in mind that the methodology calls for up to 200Hz. I will get that graph posted shortly with better explanation. I will also ensure that they all match going forward and that one offs, such as the 460Hz, are spelled out.
Sonnie 10-29-12 12:40 PM
You could post two graphs on the odd ones, one at 200Hz and another showing the higher response.
Dale Rasco 10-29-12 12:57 PM
Alright, I uploaded the images using 10Hz-200Hz versus the 10Hz-500Hz for the FR, Group Delay, Spectral Decay and Waterfall. These are probably more like what you are used to seeing Bob and should be much more consistent with the other subs that were tested.
