-   The Sub Zone (Subwoofer Testing) (https://www.hometheatershack.com/forums/sub-zone-subwoofer-testing/)
-   -   Rythmik FV15HP (https://www.hometheatershack.com/forums/sub-zone-subwoofer-testing/63536-rythmik-fv15hp.html)
Dale Rasco 11-27-12 04:28 PM
Rythmik FV15HP
Specifications
Driver
DS1510 15" high excursion with custom sensing coil
Driver materials
Black anodized aluminum with rubber surround
Cast aluminum basket
Copper flux modulation shorting rings
Amplifier
600 RMS class H patented servo controlled
Dimensions
19"(W) x 19 " (H )x 20 "(D) - (21-1/2" D with grille)
Shipping Weight
108 lbs
Frequency Response
14 - 200 Hz (-2 dB @ 14 Hz) with LFE inputs
14 - 90 Hz (-2 dB @ 14 Hz) with LINE IN inputs
Crossover slope
Selectable 12 or 24 dB / octave (PEQ and XLR versions)
Crossover range (Low pass)
25 - 100 Hz
Rumble Filter (High pass )
20 Hz 18 dB / octave
Phase response
90 degrees phase shift at 20 Hz
Phase adjustment
0 - 180 degrees continuously variable
Bass damping factor settings
high (Q=0.5), med (Q=0.7), and low (Q=1.1)
Finishes
Available in honey oak vinyl or black oak vinyl
Warranty
5 years warranty on driver and 2 years on electronics
30 day satisfaction guarantee
Manufacturers Published Measurements
http://www.hometheatershack.com/gall...le.php?n=10000
Frequency Response
http://www.hometheatershack.com/gallery/file.php?n=9997
Max Output Before Compression
http://www.hometheatershack.com/gallery/file.php?n=9998
Spectral Decay
http://www.hometheatershack.com/gallery/file.php?n=9994
Group Delay
http://www.hometheatershack.com/gallery/file.php?n=9993
Waterfall
http://www.hometheatershack.com/gallery/file.php?n=9995
Spectrogram
http://www.hometheatershack.com/gallery/file.php?n=9996
Harmonic Distortion
32 Hz
40 Hz
50 Hz
63 Hz
70 Hz
80 Hz
Peter Orrick 12-04-12 09:41 AM
re: Rythmik FV15HP
Dale-
funny thing, i'm the post who asked you about your behringer with 1.4 software, never heard back except you're checking. Reason it's funny is it for my two rythmik F12's.
Peter
aasenm 02-14-14 01:53 AM
Re: Rythmik FV15HP
What would you choose between the rythmik fv15hp or the svs sb13 For Music
Thanks Michael
Chucka 02-22-14 06:17 PM
Re: Rythmik FV15HP
Has there been any reviews of the FV12? I am looking for a MUSICAL sub that would be at home in a Condo with 5 KEF LS-50 speakers. I am concerned over too much bottom disturbing the adjoining condo units so I would prefer the LF not to go down as low as the FV15.
theJman 02-23-14 07:45 PM
Re: Rythmik FV15HP
Chucka wrote: (Post 683027)
The FV12 is long gone, since replaced by the LV12R.
Chucka 02-24-14 10:25 AM
Re: Rythmik FV15HP
Sorry - I meant the F12 family of sealed subwoofers with my most interest in the F12SE fow wife approval. I am not even sure where I came up with the FV12 designation.
BeeMan458 03-22-14 11:13 AM
Re: Rythmik FV15HP
The above graphs are open plane testing; ideal conditions. What I want to know, how well will a pair of them perform in a room our size?
...:confused:
...11Hz.
...:p
(i love our FV15HPs)
http://www.hometheatershack.com/gall...hp?n=14676&w=s
...:bigsmile:
If one buy's a pair of FV15HPs and gets them "properly" dialed in (based on REW measurements) you won't have regrets.
(dial in a pair of FV15HPs......and you'll understand what the word "spoiled" means)
ThrillCity 04-10-14 10:50 PM
Re: Rythmik FV15HP
*To Chucka:
Use a high pass? IF you're worried about too much extension there's your answer... From experience you want a subwoofer capable of playing much louder/lower than you need such that listening at normal -> loud volume is just as effortless, i.e. low distortion. People that complain about too much bottom end usually could use more bass traps/eq, it may not apply to you but I'd look down that road if you haven't already.
BeeMan458 04-11-14 08:37 AM
Re: Rythmik FV15HP
ThrillCity wrote: (Post 695833)
Complaining about too much bottom end?
...:confused:
I've read of folks complaining about not enough bottom end, but never of there being too much bottom end. What am I not understanding?
...:confused:
Have these folks who are complaining, used room measuring software to measure and graph the acoustics of their room? Are these same said people using "quality" room correction software to correct for the acoustics in their room?
Are these same folks trying to make magic with a single subwoofer based subwoofer system?
Mike0206 04-11-14 09:09 AM
BeeMan458 wrote: (Post 695889)
Complaining about too much bottom end? ...:confused: I've read of folks complaining about not enough bottom end, but never of there being too much bottom end. What am I not understanding? ...:confused: Have these folks who are complaining, used room measuring software to measure and graph the acoustics of their room? Are these same said people using "quality" room correction software to correct for the acoustics in their room? Are these same folks trying to make magic with a single subwoofer based subwoofer system?
Perhaps what he was trying to say is the bass is too boomy? That's just a guess but I agree, I want more bottom end as do most people. However if it's port chuffing then I could see someone wanting to back off a bit. That could lead someone to say too much bottom end I suppose.
