-   The Sub Zone (Subwoofer Testing) (https://www.hometheatershack.com/forums/sub-zone-subwoofer-testing/)
-   -   Genelec HTS4B (https://www.hometheatershack.com/forums/sub-zone-subwoofer-testing/64979-genelec-hts4b.html)
Dale Rasco 01-22-13 08:00 AM
Genelec HTS4B
Manufacturer Specs
Specifications
Technical Specifications
SPL
Maximum short term sine wave SPL output averaged from 30 to 85 Hz, measured in half space at 1 meter ≥ 112 dB SPL
Drivers
Bass 12" Active + 2 x 12" Passive radiator
Free field frequency response 18 Hz - 120 Hz 3 dB
Amplifier power /ch
Bass 400 W
Speaker dimensions (H x W x D)
mm 518 x 483 x 465 mm
inches 20 3/8 x 19 x 18 5/16"
Speaker weight 37 kg (81 lbs)
Manufacturer Published Measurements
N/A
Frequency Response
http://www.hometheatershack.com/gall...le.php?n=10607
Max Output Before Compression
http://www.hometheatershack.com/gall...le.php?n=10614
Spectral Decay
http://www.hometheatershack.com/gall...le.php?n=10609
Group Delay
http://www.hometheatershack.com/gall...le.php?n=10610
Waterfall
http://www.hometheatershack.com/gall...le.php?n=10611
Spectrogram
http://www.hometheatershack.com/gall...le.php?n=10612
Harmonic Distortion
http://www.hometheatershack.com/gall...le.php?n=10615
Measurement Methods
16 Hz
65536-point spectrum using Rectangular window and no averaging
Input RMS 88.8 dB
Distortion at 16.1 Hz, -32.0 dB FS based on 8 harmonics:
THD 21.5407 %
THD+N 61.0083 %
2nd harmonic 16.4715%
3rd harmonic 13.1180%
4th harmonic 1.5583%
5th harmonic 3.4650%
6th harmonic 1.0912%
7th harmonic 0.8824%
8th harmonic 1.5656%
9th harmonic 1.3238%
20 Hz
Input RMS 105.8 dB
Distortion at 20.1 Hz, -14.7 dB FS based on 8 harmonics:
THD 10.1934 %
THD+N 56.9923 %
2nd harmonic 2.8739%
3rd harmonic 7.4539%
4th harmonic 1.3508%
5th harmonic 5.6885%
6th harmonic 1.0330%
7th harmonic 1.9937%
8th harmonic 0.7810%
9th harmonic 0.4983%
25 Hz
Input RMS 108.9 dB
Distortion at 24.9 Hz, -16.1 dB FS based on 8 harmonics:
THD 9.1852 %
THD+N 87.2380 %
2nd harmonic 5.3118%
3rd harmonic 4.8023%
4th harmonic 3.5802%
5th harmonic 2.7455%
6th harmonic 1.9302%
7th harmonic 2.4143%
8th harmonic 1.3568%
9th harmonic 1.1579%
32 Hz
Input RMS 106.6 dB
Distortion at 31.6 Hz, -12.5 dB FS based on 8 harmonics:
THD 2.9031 %
THD+N 22.7580 %
2nd harmonic 1.8047%
3rd harmonic 2.2311%
4th harmonic 0.2045%
5th harmonic 0.3446%
6th harmonic 0.0704%
7th harmonic 0.1103%
8th harmonic 0.0604%
9th harmonic 0.1085%
40 Hz
Input RMS 110.5 dB
Distortion at 39.9 Hz, -8.6 dB FS based on 8 harmonics:
THD 2.9688 %
THD+N 25.4326 %
2nd harmonic 2.3533%
3rd harmonic 1.4351%
4th harmonic 0.7178%
5th harmonic 0.4498%
6th harmonic 0.4270%
7th harmonic 0.3726%
8th harmonic 0.3259%
9th harmonic 0.2676%
50 Hz
Input RMS 113.0 dB
Distortion at 49.9 Hz, -6.3 dB FS based on 8 harmonics:
THD 1.3837 %
THD+N 31.8130 %
2nd harmonic 1.1032%
3rd harmonic 0.7445%
4th harmonic 0.2345%
5th harmonic 0.1866%
6th harmonic 0.1544%
7th harmonic 0.1290%
8th harmonic 0.0866%
9th harmonic 0.0756%
63 Hz
Input RMS 114.3 dB
Distortion at 63.1 Hz, -4.6 dB FS based on 8 harmonics:
THD 2.0565 %
THD+N 13.1972 %
2nd harmonic 0.8997%
3rd harmonic 0.6898%
4th harmonic 1.6090%
5th harmonic 0.4370%
6th harmonic 0.2517%
7th harmonic 0.1831%
8th harmonic 0.1600%
9th harmonic 0.2040%
80 Hz
Input RMS 113.2 dB
Distortion at 80.1 Hz, -5.6 dB FS based on 8 harmonics:
THD 0.8366 %
THD+N 4.6619 %
2nd harmonic 0.8128%
3rd harmonic 0.1265%
4th harmonic 0.0775%
5th harmonic 0.0970%
6th harmonic 0.0511%
7th harmonic 0.0509%
8th harmonic 0.0382%
9th harmonic 0.0347%
Dale Rasco 01-28-13 03:49 PM
Nice!
AudiocRaver 01-30-13 10:17 PM
Re: Genelec HTS4B
291 Attachment(s)
Are those all your own measurements? Very nice.
Do you take your measurements outside? I am more than a little curious about your setup and methods, your graphs are all so super clean. What mic did you use?
Dale Rasco 02-01-13 08:15 PM
Re: Genelec HTS4B
AudiocRaver wrote: (Post 586679)
Sorry I missed this post. I use the IBK setup, the methodology and testing equipment is listed in The Sub Zone.
DanTheMan 02-04-13 07:34 PM
Re: Genelec HTS4B
That's certainly a very competent sub! All these subs are making me jealous. Mine just can't do what this one will.
Dan
