Inuke 3000 - Is it faulty or user error - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 22 Old 03-02-15, 03:06 PM Thread Starter
Hi, I know there are lots of inuke threads already but I was hoping someone could help me.
I have an inuke powering a sunfire hrs12 subwoofer that had a faulty amp. Sunfire say the driver is 4 ohm and the amp was 1000rms. It has worked but never as well as the original amp. I have now switched to an Anthem mrx and its even worse and at first I though maybe its the eq but I have decided to investigate.
First I tried my old rel quake direct to the anthem (full volume on the rel) and it rattle my little room to bits during the anthem sweeps and when I play a test tone. Not pretty but it is loud (bear in my mind my room is only just over 3x3)
Next I swap cable to the inuke/sunfire and the anthem sweeps are very quiet and the test tone is quiet and actually is inaudible under 40hz.
The inuke set up is a splitter into the anthem then a twin rca to xlr connecting to the inuke. The inuke is in bridge mode. A 4 pin Neutrik wired to 1+ Pos and 2+Neg. This then goes to the subwoofer driver.
The lights on both sides of the inuke work but rarely go above 1 orange light. I have noticed that only the left volume nob works. Turn the right one and it has no effect. Is this something to do with bridged mode?
I tried taking the splitter off and trying each rca cable direct and only one of them has any output. I then tried swapping the XLR around with the rca cable was not working and it worked with one but not the other.
So I am now confused whether maybe its a problem with the inuke with one channel not working that so happen to go when I added the Anthem or whether that is just normal behaviour when in bridged mode or maybe it was never connected up correctly.
The only thing I can think of is figuring out how to wire the output to stereo and then this could tell me whether it is a quirk of bridged mode or whether one channel is dead.
If anyone has any suggestions I would really appreciate it.
jobby01 is offline
post #2 of 22 Old 03-02-15, 06:06 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Inuke 3000 - Is it faulty or user error
First, welcome to the Forum!
This cable connection scheme does not make any sense:
jobby01 wrote: View Post
Regardless, it’s typical for an amp in bridged mode to use only a single input, not both. I suggest consulting the manual for how to set up and connect the amp for bridge mode (I couldn’t find one on line).
post #3 of 22 Old 03-02-15, 06:34 PM
chrapladm's Avatar
Papi
Do you have a multimeter?
Simplest thing would be to just connect the speaker directly from one channel and see if it plays or not. Then try bridged after you try this on both channels.
"Music is the space between the notes"
[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.
chrapladm is offline
post #4 of 22 Old 03-02-15, 08:38 PM
I was reading about your Sub it is a 4 ohm driver. The 3000 can run either a 2,4,or 8ohm load. If you are wanting to use the bridged option in your case you cannot run the 3000 at a 2ohm load bridged it is too much for the amp. The max it can see in bridged mode is 4 ohm and it will give you 1100watts all day long. Since you have a 4 ohm sub you have to use +1 -1 and only use channel A. In theory you should get almost 900 watts out of the amp to your sub. I hope this helps
nwf477 is offline
post #5 of 22 Old 03-03-15, 12:33 PM Thread Starter
Hi Guys thanks for taking the time to reply.
The manual doesn't mention much about bridging and how to hook up to a single rca output. Its nearly all about dsp. I didn't know if bridge mode required an input into channel A and channel B to work. I chose the splitter and double cables based on advice from going though forums.
I am now trying with a single rca to single channel. I am trying each one individually and it is 'stereo full range mode'
Input to channel A using a single connection to output A (wired 1+ and 1-) I get a very week output similar to when in bridged mode.
Input to channel B using a single connection to output B (wired 1+ and 1-) and I get no output.
Input to channel B using a single connection to output B (wired 2+ and 2-) and I get no output.
I have taken the lid off the inuke and no obvious signs of damage although it would have to be pretty obvious for me to spot it.
From the testing above it would seem that channel a doesn't have the power to move a 12 inch 4ohm driver and channel B is not working at all.
I did start getting the problem when I change receiver so I could change it back but I am not sure how that would make a difference and I could try connecting the inuke to some normal speakers but again I am not sure that's going to tell me much.
Am I missing something obvious?
jobby01 is offline
post #6 of 22 Old 03-03-15, 01:08 PM
This may be an input sensitivity issue. I can't find the input sensitivity specs for the Inuke amps anywhere.
Do you know what the preouts on your pre/pro are rated for?
Also, Is this the DSP model? If it is the DSP model, it looks like you can boost the gain in the DSP section.
Not sure if it will be enough boost, but it may be worth checking.
Insearchof is offline
post #7 of 22 Old 03-03-15, 02:07 PM
If you did not cook the amp by bridging the amp to a 2 ohm load hopefully not do you have a rcvr with a sub out? If yes is it a newer or older model? If that checks out what type of cable do you have from the rcvr to the amp? It should look like this: http://images.monoprice.com/productl...ages/47751.jpg. You might have to get a "smart box" it will balance the output of the rcvr to the amp. The manual is not very clear at all. Is the amp still under warranty? What is the make and model of your rcvr you said switched them any way you can provide pictures? I know for a fact my 3000DSP pushes my 18" sub pretty hard it will give me a headache. It has to be something simple or a bad amp, what color are the gain knobs when the amp is on? Orange or Red?
nwf477 is offline
post #8 of 22 Old 03-03-15, 03:22 PM Thread Starter
Yes the cable is like that but I had two of them. The RCA splitter was on the line out and then the 2 cables went to the nuke (channel A and B). It worked for about a year like that and it would lights upto maybe 2 orange lights and occasionally 3 for a second. This was using my Pioneer vsx lx53 receiver. I swapped to an Anthem MRX500 recently and the bass just seemed to disappear. At first I thought it was the Anthems ARC eq'ing the sub (which the Pioneer didn't) making it too polite but when I decided to investigate further thats when I found that it doesn't seem to be working.
I suspect I have damaged channel B and the amp is not under warranty anymore (its a non DSP model by the way)
I still have my Pioneer receiver but its hooked up in another room at the moment. I am going to try it with the inuke and see if I get any more response out of channel A. I'll take some pics of my setting / cable too.
jobby01 is offline
post #9 of 22 Old 03-03-15, 03:32 PM
Not trying to sound pessimistic but if it worked before and then you hooked up the Anthem and now zip does not look good. Were you running the amp bridged before? I am not an expert using the pro amps is all new to me but I was told you cannot run the amp in bridged mode at 2 ohms. You can run it in stereo at 2 ohms per channel, that is my plan once I get the second sub built. If all else fails try hooking it up the way it use to be before swapping rcvrs.
nwf477 is offline
post #10 of 22 Old 03-03-15, 03:39 PM
The manual for the Anthem lists the sub channel as having 7.2Vrms maximum output which I suspect is far more than the Pioneer sub pre out can muster.
The Inuke, even with a bad channel will still push 680 watts rms @ 4 ohms for the still functioning channel.
That should make that sub work.
3000 , error , faulty , inuke , user
