Amplifiers Tested - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 14 Old 08-07-08, 12:24 PM
Mike P.'s Avatar
Mike
Re: Amplifiers Tested
The O-Audio BASH 500 is the better amp with an adjustable subsonic filter and EQ. Check the parameters that you have for the MJ-18. They may be the older ones. It has been replaced with the MJ-18M, with a lower Fs and higher Xmax. Definitely an improvement.
http://www.mach5audio.com/zen/index....roducts_id=182
We're all in this together!
Mike P. is offline
post #12 of 14 Old 08-07-08, 12:28 PM Thread Starter
Matt
Thank you Mike P.!
I also am very interested in the XO-12 from Torrent Audio.
Problem is the MJ-18M, Oaudio BASH500, and mdf, etc. would be more than $450.
Whereas the Bash 300 or SA 240 would save me over $100. For a first build meant to be super low budget I'm not sure if the 2.5dB or so I'd gain from the extra wattage would be worth it.
If the 500 = ~433w and the 300= ~340w there is even less difference.(those are numbers I've come across on the net, not sure if valid)
But then if I'm considering the BASH300, why not the SA240 with it's added features since I'd only lose another 1db or so?
As you can see I'm confused, what's your thoughts?
E-A-G-L-E-S is offline
post #13 of 14 Old 08-08-08, 09:49 AM
Ricci's Avatar
Josh
The MJ18M will make the most out of your available watts, since it should be more efficient than the smaller 12's and 15's. Why not try the 300w Oaudio Bash it's only $159. That's $314 for the MJ18 and the amp.
Ricci is offline
post #14 of 14 Old 08-08-08, 10:02 AM Thread Starter
Matt
Ricci wrote: View Post
Perhaps I misunderstood, but I have read that the 300w from PE and Oaudio are the same and only the Bash 500 is altered by Oaudio?
If that's true, PE has it for $35 less and the SA240 for another $15 off but with itsa' EQ.
Other drivers I am considering seriously besides the MJ-18M:
Torrent Audio XO-12
Dayton HF15
Dayton HF12
Today I will have time to model the MJ-18M.
amplifiers , tested
