Behringer iNUKE1000DSP Interconnect cable - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 5 Old 06-05-18, 09:43 PM Thread Starter
mtavares's Avatar
Hi,
I would much appreciate to confirm what is the proper interconnect cable for the Behringer iNUKE 1000DSP? Currently I am using the following XLR to RCA cable.
https://www.amazon.com/Monoprice-Con...ice+xlr+to+rca
However, I am not sure that we are handling with an unproper gain between the subwoofer output of my Marantz SR7002 receiver and the INUKE. Are the following options more appropriate?
a) RCA to 1/4 Adapter + RCA cable
https://www.amazon.com/MOBOREST-6-35...+to+1%2F4+mono
b) RCA to 1/4 cable (stereo)
https://www.amazon.com/dp/B006H9ZDRI...078R2FBC9?th=1
Thanks in advance by the support.
Best Regards,
QJA
Marcos
mtavares is offline
post #2 of 5 Old 06-05-18, 10:01 PM
HTS Senior Moderator
fusseli's Avatar
Re: Behringer iNUKE1000DSP Interconnect cable
What's the actual problem with the gain you are having?
I go straight from my Denon X3300W with my inuke with a mono 1/4" to rca adapter and it works great.
fusseli is offline
post #3 of 5 Old 06-05-18, 10:45 PM Thread Starter
mtavares's Avatar
Currently, I am clipping this amplifier driving a single subwoofer DIY (Epic 12 driver) in a Bridge mode.
My concern is that using the RCA to XLR cable, I am reducing the gain by 6dB?
In the spec of the Behringer iNUKE 1000DSP it states that the input impedance is 10Kohms for the unbalanced and 20Kohms for the balanced. Considering this data, will the XLR conector cause and lower gain in the chain?
The way you are connecting, seems more appropriate.
Maybe I am missing something.
QJA
Marcos
mtavares is offline
post #4 of 5 Old 06-06-18, 12:06 AM Thread Starter
mtavares's Avatar
After some research, I verified that the options are equivalent, based on the two points that I have not understood initially.
1) iNUKE User Manual
5.2.1 Audio inputs
Each channel input uses combo jacks that can accept both balanced XLR and
" TRS stereo connectors, as well as unbalanced " TS connectors. To deploy XLR
connectors for unbalanced signals, bridge pins 1 and 3;
mono " TS connectors
do not require any alteration to carry unbalanced signals.
2) Monoprice cable description
An XLR to RCA cable converts a balanced audio signal into an unbalanced signal. This is good for sending audio signals from an XLR source to an RCA input, or vice versa. Regardless of direction, the result will be an unbalanced signal.
This is a premium quality cable with gold plated connectors at each end. The cable is made with two 16 AWG oxygen-free copper conductors, in a twisted-pair arrangement, and is shielded along the full length with copper braid with 97.5% coverage.
This cable uses the standard pinout with pins 1 and 3 of the XLR connector wired to the shield of the RCA plug and pin 2 of the XLR connector wired to the tip of the RCA plug.
https://www.monoprice.com/product?p_id=4777
I apologize by my lack of initial research. You can simulate an unbalanced signal with this cable.
QJA
Marcos
mtavares is offline
post #5 of 5 Old 06-06-18, 12:41 AM
fusseli's Avatar
No problem.
Clipping the amp might mean the gain is too high, not too low.
fusseli is offline
behringer , cable , interconnect , inuke1000dsp
