500K Ohm Mini Trim Potentiometer - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 14 Old 05-07-09, 12:50 PM Thread Starter
George
Re: 500K Ohm Mini Trim Potentiometer
I understand the first part, but can you help me out on the subtraction part. Suppose I leave one pin free for measuring purposes on a 100K pot. I get a reading of 75K. What is the value?
joorge is offline
post #12 of 14 Old 05-07-09, 05:15 PM
Banned!
SturmMD
Before you solder the pot in measure the full resistance (outer pins). It won't be exactly 100K for example. Also turn it to about 1/4 1/2 and 3/4 positions and measure both sides. Check that they add up to close to the same value (~100K) for each position.
Then when it is soldered in, if you measure from the free pin to the center and get a reading of 75K that means that (100K-75K)=25K is what it is set to. The measurement taken before soldering will make this calculation more accurate. And since you're spending the money on the really precise 10 turn pots it would be a waste to not use this technique.
SturmMD is offline
post #13 of 14 Old 05-08-09, 12:00 AM Thread Starter
George
Got it. Thanks for taking the time. I'm still trying to figure out where they put the carburetor on my car.
joorge is offline
post #14 of 14 Old 05-08-09, 05:31 AM
Mike P.'s Avatar
Mike
You could try adding the potentiometer to your carburetor and dialing in the gas mileage!
We're all in this together!
Mike P. is offline
500k , mini , potentiometer , trim
