amp option - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 25 Old 05-23-09, 11:00 PM
Mike P.'s Avatar
Mike
Re: amp option
so could you tell me whats the best options in running my setup
That will depend on what net volume and tuning frequency you choose.
We're all in this together!
Mike P. is offline
post #12 of 25 Old 05-24-09, 02:11 PM
ironglen's Avatar
Glen
Re: amp option
meccalli wrote: View Post
ok well i guess ill be going behringer.....so could you tell me whats the best options in running my setup-by that i mean the greatest power output with the lesser of all risks-fi Q's come in D1 & D2 coils and im gonna be running both of the single 2500.
Found the samson pg2200 here for a bit more to your door. UPDATE: I had a second linked company, Musician'sBuy.com, but a BBB check showed sketchy history (and address changes) with the company: advise HTS'ers look it up for yourselves. The first, SamAsh, had an excellent rating.
The pg3800 can be had for $50 more here, which I think may be better suited for you since you're running a pair, I don't know. How much RMS power is optimal for a Fi 18" speaker? (Or the Mal-x? not trying to thread steal) The samson's have a 3 year warranty if they are authorized dealers (I have to check). Anyone ever seen any test results on the samson pg2200 or pg3800?
Last edited by ironglen; 05-24-09 at 04:44 PM. Reason: added links, BBB check showed poor business rating
ironglen is offline
post #13 of 25 Old 05-25-09, 02:50 PM Thread Starter
brandon
Re: amp option
i mean..that say the amp runs better on 8ohms per channel for 600watts(just reference..not real specs)..will that be good..so from there i can choose the coils for the Q's-but im going with a 18 cubic ft box and i wanna port around 20-24
i was just looking at the ep 2500 tests on [email protected] 2 ohms/channel-it puts out 819 rms however @ 4ohms/channel the output is 633 rms so i was thinking since 2 ohm kinda pushes the amp to limits and going frorm 633 - 819 rms wont make a difference in spl...whats the point..maybe dual 2's in series per channel is a good idea......do you think the Q's will run well on 633 rms?
meccalli is offline
post #14 of 25 Old 05-26-09, 04:38 AM
Mathias
Re: amp option
I don't understand. The EP2500 is perfectly stable in 2ohm stereo. "pushing its limits", what do you mean? Every amp is pushed when it's near its capacity, but that doesn't matter as long as it works and doesn't overheat. The EP2500 bridged in 4ohm, or stereo 2ohm doesn't get too hot, it works.
It's designed for that.
fackamato is offline
post #15 of 25 Old 05-26-09, 05:04 AM
Mike P.'s Avatar
Mike
Re: amp option
Wiring a pair of D1's for a 4 ohm load would allow you to run the amp in bridged mode which is 2400 watts.
Mike P. is offline
post #16 of 25 Old 05-27-09, 07:55 AM Thread Starter
brandon
Re: amp option
is that an rms rating?
meccalli is offline
post #17 of 25 Old 05-27-09, 08:33 AM
Mathias
Re: amp option
The EP2500 gives at least 2000 watts continous in 4ohm bridged mode, see this:
http://www.avsforum.com/avs-vb/showt...9#post10689199
(bridged here: http://www.avsforum.com/avs-vb/showt...5#post10755565)
Notice the distorsion, it's very low. You get more watts, but at higher distorsion.
post #18 of 25 Old 05-27-09, 10:52 AM
Ricci's Avatar
Josh
Re: amp option
Actually it's more like 825w per channel into 2ohms and an estimated 1650w at 4 ohm bridged as tested in the link above. We are talking about bass here. 1khz is a field day for any amp. Look at the 20hz results. It kept popping fuses when the 4ohm bridge test was tried. BTW this is not a bad showing for it. It should be quite a bit better when actual program material is used.
Ricci is offline
post #19 of 25 Old 05-27-09, 10:55 AM
Mathias
Re: amp option
Ricci wrote: View Post
Actually it's more like 825w per channel into 2ohms and an estimated 1650w at 4 ohm bridged as tested in the link above. It kept popping fuses when the 4ohm bridge test was tried. BTW this is not a bad showing for it. It should be quite a bit better when actual program material is used.
That's true , sinus waves puts the maximum amount of pressure on the amps, it's nowhere near program material as you say.
post #20 of 25 Old 05-27-09, 10:57 AM
Ricci's Avatar
Josh
Re: amp option
fackamato wrote: View Post
And still a great showing for the amp that sells for so cheap.
Ricci is offline
option
