Alternates to the EP 2500 to power a maelstrom X? - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 32 Old 07-28-09, 06:31 PM
sub_junkie's Avatar
Dylan
Re: Alternates to the EP 2500 to power a maelstrom X?
Why hasn't anyone mentioned the Crown XLS 802D amps? If you go to Guitar Center's website, you can get Factory B Stock for around $425 as far as I can remember. (I'm not sure if that would be a very good decision to get the B stock ones or not...)
That is hopefully what I am going to get when my Mal-X arrives, and as soon as Christmas comes....... lol.
sub_junkie is offline
post #22 of 32 Old 07-28-09, 07:18 PM
Mike
sub_junkie wrote: View Post
Crown only specifies a 8 ohm mono rating for the 802D. I don't think this amp would be good with the Mal-X. You would be better off with the EP2500 and you would save a few hundred to boot.
If you have to have it then google the amp and you will probably get a good price for a new A stock.
Crown probably does not recommend this amp be run bridged into a 4 ohm load which is what the Mal-X is.
sub_crazy is offline
post #23 of 32 Old 07-28-09, 09:02 PM
sub_junkie's Avatar
Dylan
Last that I heard, mdrake runs his Mal-X (or possibly a friends, I'm not sure) into the 4 ohm bridged mono operation. The only reason why I want to get the XLS 802D is becuase the bass is more crisp from it.
post #24 of 32 Old 07-29-09, 12:05 AM
Mike
Mdrake runs his Mal-X into the 4 ohm bridged mono operation. The only reason why I want to get the XLS 802D is becuase the bass is more crisp from it.
Good to hear you already have someone using it with success. Crown makes very good amps, have you ever thought about using there XTi series? They include some built in DSP to help tune your sub.
Since your a sub_junkie you will really like the Mal-X.
post #25 of 32 Old 07-29-09, 12:34 PM
sub_junkie's Avatar
Dylan
I don't have enough money to get the XTi series (I wish I did)
I can't wait until my Mal-X gets here. I have only heard commercially bought subs under $250 (besides movie theaters), so I'm sure that this will be a BIG suprise.
I will tell you how the Crown does in 4 ohm bridged mono.
I read on a Ebay selling of the XLS802D that it can safely operate in 4 ohm mono operation. I know that it's an Ebay thing, but hopefully it will be true
post #26 of 32 Old 07-29-09, 12:53 PM
Mike
When you get ready to build make sure you come back here if you need any help or advice. There are a lot of very knowledgeable DIY builders around who are always very kind with there help.
I am always happy to offer any help as well but I freely acknowledge that there are others who are far more advanced than I.
Good luck and have fun.
post #27 of 32 Old 08-01-09, 02:02 AM
michael
Send a message via MSN to michael hurd
The XTI 1000 that Chasw98 tested ( over on the AVS forum ) didn't fare well at low frequencies into 4 ohms at all. There was a bit of a debacle over the testing regimin, but all of the amps he tested were tested in the same way.
You can google it to get the link. ( measuring amplifiers )
michael hurd is offline
post #28 of 32 Old 08-01-09, 02:12 AM
Crown Audio XLS/802 Series Specifications Sheet
Load impedance
Stereo..............4-8 ohms
Bridge mono..........8 ohms
It will give u 800 watts (per ch.) into 4 ohms
Mika75 is offline
post #29 of 32 Old 08-02-09, 08:48 AM
kouack
The Crown XLS serie will do 4 ohms bridged, this question is asked about once a month over Crown forum and one of the tech rep said they cannot published it for some CE compliance reason.
kouack is offline
post #30 of 32 Old 08-02-09, 09:12 AM
Mike P.'s Avatar
Mike
kouack wrote: View Post
I read up on that issue, it's the possibility of exceeding 15 amps at 120V. From the Crown forums:
The 802D could possible exceed 15 amps under certain 2-ohm per channel/4-ohm Bridge-Mono "Nominal" loads and due to US regulatory compliance reasons we could not officially publish a 2-ohm/4-ohm Bridge-Mono spec for it.
To keep the entire XLS line specifications uniform it was decided to drop the 2-ohm/4-ohm Bridge-Mono spec on the 202, 402 and 602 from the sheet as well.
Internationally with most countries running at 240v AC this is not an issue - for as Supply Voltage goes up the Current requirements go down so not an issue there.
I just wondering if the amp doesn't meet US regulatory compliance for a 4 ohm bridged configuration and something goes wrong with the amp, would the amp we warrantied?
We're all in this together!
Mike P. is offline
2500 , alternates , maelstrom , power
