1000W or greater Plate Amps? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 13 Old 01-28-10, 04:25 AM Thread Starter
AngelEyes's Avatar
Adam
Send a message via AIM to AngelEyes
Hi,
I am looking for a 1000, 1500 or 2000W (into 4 Ohms) plate amp for some projects I am musing over. If you want 500W it seems there is plenty of choice but get to a 1000W I can only find Dayton and they seem quite limited connectivity wise. I also have no idea of the quality either...
Maybe I am just not looking in the right places, any suggestions?
Thanks,
Adam
AngelEyes is offline
post #2 of 13 Old 01-28-10, 08:19 AM
Moonfly's Avatar
Re: 1000W or greater Plate Amps?
Ive never seen a plate amp over 1000 watts, and like you say they're almost all 500. What is it you want them for, wont the pro amps do. If you looking for better power, Face Audio get mentioned on here from time to time but they dont do plates.
Moonfly is offline
post #3 of 13 Old 01-28-10, 09:09 AM Thread Starter
AngelEyes's Avatar
Adam
I want an plate amp for my current PP AV15-X sub, or rather its next generation and 1000W won't cut the mustard. Pro amps are too noisy even with a fan upgrade and take up space I don't have (currently it sits on top of my sub). I just want a tidy solution, an active sub rather than the passive one I currently have.
Adam
post #4 of 13 Old 01-28-10, 09:41 AM
Moonfly's Avatar
I think your only solution will be to add in a LTC, you wont need the same power then. In fact, depending on its design even 500 watts could be too much.
Other than that, I think if you want 2k watts your going to need a couple plate amps, which will get complicated.
<EDIT>
Your a PC man, why couldnt you mod the pro amp with some nice silent water cooling?
Moonfly is offline
post #5 of 13 Old 01-28-10, 11:23 AM
Jerm357's Avatar
Jerm357
ED sells a 1300 watt plate amp, but its not cheap.
http://www.edesignaudio.com/product_...roducts_id=500
Jeremy
Jerm357 is offline
post #6 of 13 Old 01-28-10, 12:04 PM Thread Starter
AngelEyes's Avatar
Adam
Hi Jeremy,
Thanks for the link
Adam
post #7 of 13 Old 01-28-10, 01:11 PM
Jeremy
Jerm357 wrote: View Post
And it probably wouldn't be worth buying if it was
To the OP, the Yamaha pro amps use variable speed fans and IIRC shut them off completely at low temps. The P series is cheap for pro amps, but not cheap like, say, a Behringer would be in both price and quality.
Oklahoma Wolf is offline
post #8 of 13 Old 01-28-10, 06:53 PM
Marce
I have the ED LT1300 plate amp powering a AV15X sub and simply is great. It produces the advertised power and is convenient to use. When I bought it, it was $350 and now it's around $450. For the money, it's probably the best plate amp out there.
spanish68 is offline
post #9 of 13 Old 01-29-10, 04:25 PM
Veltinorian's Avatar
Velti
Or you could buy cheap 2x 500 or 2x1000watts plate amps and manage somehow to invert the one output and connect the sub between one non-inverted and one inverted output - thus the power is 4 times higher as with one amp. The so called bridge mode P=U^2/R. But be careful that power may be too high for your sub.
Veltinorian is offline
post #10 of 13 Old 01-29-10, 05:12 PM
lsiberian's Avatar
lsiberian
AngelEyes wrote: View Post
Hi,
Thanks,
Adam
I want a truck that actually gets 30 miles to the gallon, but as with plate amps what you ask isn't economically feasible for plate amp makers.
Your best option is the Yamaha Pro Amp P7000. It is very solid and can take a lot of power it also remains very quiet.
Just remember that you need a 2000w amp to truly upgrade from a 1000w one.
lsiberian is offline
1000w , amps? , greater , plate
