Amp hookup - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 15 Old 03-09-10, 04:58 AM Thread Starter
John
Amp hookup
Hope somebody can point me in right direction. I have coming a Behringer EP4000 to hookup up to an 18 Maelstrom and want to make sure I understand the proper wiring. My receiver is the Pioneer Elite 23. I also ordered a RCA to XLR cable to connect from receiver to amp and speaker wire to go from amp to sub. I figured to come from LFE plug to one side of amp and then run amp bridged to sub. This sounds to easy, am I missing something? I've never dealt with any pro audio stuff so any input would be welcomed. Thanks.
jimmyswan is offline
post #2 of 15 Old 03-09-10, 10:09 AM
tcarcio's Avatar
TC
Re: Amp hookup
You got it right. Just make sure you set the dip switches on the amp correctly for bridge mode and you will be good to go. When you get the amp and are ready to hook it up and have questions just ask and someone will be glad to help.
tcarcio is offline
post #3 of 15 Old 03-09-10, 11:09 AM
Kevin
Re: Amp hookup
Remember Voice Coils wired in series too. Otherwise your amp will see a 1-ohm load.
Kevin Haskins
Exodus Audio
Kevin Haskins is offline
post #4 of 15 Old 03-09-10, 01:05 PM
dboff01
Re: Amp hookup
The Behringer EP4000 does not include a subsonic filter, correct? If not, where would a subsonic filter fit in this connection chain for a ported design?
dboff01 is offline
post #5 of 15 Old 03-09-10, 02:08 PM
tcarcio's Avatar
TC
Re: Amp hookup
I believe it does have filters. One is 50hz and one is 30hz. But you want to go lower than that with your sub anyway.
tcarcio is offline
post #6 of 15 Old 03-09-10, 03:27 PM
dboff01
Re: Amp hookup
tcarcio wrote: View Post
Okay ... so lets imagine I want to use an EP4000 with a HP filter @ 18 Hz.
Would I disable the HP filter options presented by the EP4000 (30/50) and introduce a filter somewhere else in the signal chain? Before or after the amp? Is there a standalone HP filter module/circuit used by people in this forum?
Thanks
dboff01 is offline
post #7 of 15 Old 03-09-10, 05:32 PM
tcarcio's Avatar
TC
Re: Amp hookup
dboff01 wrote: View Post
Thanks
Yes you would set both filters to the off position. I used my sms-1 to eq and HP my sub so that is all I have any experience with. I think alot of people here use the BFD and REW with their subs, there is some info here...http://www.google.com/url?q=http://w...ZrHHU1HgqT6NrA REW forum is here....http://www.hometheatershack.com/forums/rew-forum/
tcarcio is offline
post #8 of 15 Old 03-09-10, 06:21 PM Thread Starter
John
Re: Amp hookup
I'm glad the question about the filter was brought up. Mine is a sealed enclosure, where do I want to set mine? I have no EQ as of now but possibly later. Thanks for the replies already.
post #9 of 15 Old 03-09-10, 07:37 PM
dboff01
Re: Amp hookup
jimmyswan wrote: View Post
You don't require a high-pass filter for a sealed enclosure. For a ported enclosure the driver effectively unloads near the tuning frequency of the box which can damage the driver if not filtered. For a sealed enclosure you may want EQ to boost the low-end to flatten the response but it is not required to protect the driver. WinISD is great for modeling the response of a given sub-woofer design with/without EQ.
dboff01 is offline
post #10 of 15 Old 03-10-10, 04:52 AM Thread Starter
John
Re: Amp hookup
Thank you, I will download WinISD this afternoon and play around with it.
hookup
