Amps for subs - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 23 Old 03-24-10, 12:12 AM Thread Starter
bambino's Avatar
bambino
Amps for subs
I noticed that most folks on this site are using the beheringer amps to drive there subs i know that there are several other options out there but just wondering what the other guys are using and at the same price point or has the beheringer been the most reliable and powerful of the pro sound amps available? Is it the most flexable as far as bridging go and able to run cleaner and more powerfully then others, your guys input would be great as i am in the market for somthing to drive my 2 15'' dual 4ohm subs. And if i put this post in the wrong location please move it to it's proper thread locations. Thanks guys.
bambino is offline
post #2 of 23 Old 03-24-10, 03:02 AM
Banned!
Re: Amps for subs
I have moved your post to the DIY section so some of the DIY experts can assist bambino
recruit is offline
post #3 of 23 Old 03-24-10, 11:11 AM Thread Starter
bambino's Avatar
bambino
Re: Amps for subs
Once i started threading i figuerd i should have put it somewhere else, Thanks.
bambino is offline
post #4 of 23 Old 03-24-10, 11:40 AM
dyohn's Avatar
David
Re: Amps for subs
The Behringer amps provide a lot of oomph for the price and can be an excellent solution for some subwoofer applications. That being said, they are pro-line designs and as such can have fan noise, s/n and distortion issues depending on how you use them, plus they require using XLR inputs which can be problematic for some users. Since they are not designed as subwoofer amplifiers an external low-pass crossover and possibly a subsonic filter will need to be provided from some other device.
Depending on your needs, you might be better off using a dedicated subwoofer amplifier. You mention using 2 DVC 4-ohm drivers. What's the make and model and how are they being used?
dyohn is offline
post #5 of 23 Old 03-24-10, 12:21 PM Thread Starter
bambino's Avatar
bambino
Re: Amps for subs
They are kicker cvx car subs set up in separate boxes, right now they have to be wired at 8ohms so i don't kill the dayton HPSA1000s i have driveing them. Thats why i was thinking pro sound amps as they can deliver more power at a lower impedance then i'm currently able to do.
bambino is offline
post #6 of 23 Old 03-24-10, 12:54 PM
Moonfly's Avatar
Re: Amps for subs
The Behringer amps arent bad. The S/N ratio was always considered a non issue personally, but I did notice Audyssey auto setup pick up on it and found it a bit picky in that regard so there are improvements to be had, but they cost, and any improvements over Behringers will cost considerably more. That said, the S/N ratio has never been an audible issue for me, only with Audyssey.
Also, you can use phono (RCA) connectors via an adapter just fine which is what I do, so the XLR inputs can be dodged easy enough.
Moonfly is offline
post #7 of 23 Old 03-24-10, 12:56 PM
Mike P.'s Avatar
Mike
Re: Amps for subs
If you're going with a 2 ohm load then a Behringer would be a good choice. As David pointed out, you'll also need a hi-pass filter like the Reckhorn B1.
We're all in this together!
Mike P. is offline
post #8 of 23 Old 03-24-10, 01:44 PM Thread Starter
bambino's Avatar
bambino
Re: Amps for subs
Can the behringer run two seperate 2ohm loads so i could drive both subs off one amp or would i need two? Thanks for the input guys.
Mike by the way i just put the twins down for there nap so i can get to finishig the second sub, can't wait!
bambino is offline
post #9 of 23 Old 03-24-10, 01:44 PM
dyohn's Avatar
David
Re: Amps for subs
bambino wrote: View Post
Using Comp VX in the home is probably the problem, not the amount of power you have going to them. What sort of enclosures are you using?
dyohn is offline
post #10 of 23 Old 03-24-10, 01:47 PM Thread Starter
bambino's Avatar
bambino
Re: Amps for subs
Where can i find the rechorn B-1? The sight i pulled it up on was in german, i have a hard enough time time speaking english. LOL!
bambino is offline
amps , subs
